400
Programmatically adding columns
Hi!
I add columns to my grid using custom code. However when I set some data on my binding source, additional columns are added depending on data. Is it possible the grid layout not to be affected while binding data? I remember that in some standard microsoft grid there was a propery call AutomaticallyGenerateColumns which was doing exactly this. Is there something like it on ultragrid?
  • 469350
    Verified Answer
    No, there is no AutoGenerateColumns property on the grid. The grid will always create all of the columns that exist in the data source. You cannot remove a bound column. But you can hide a column using the Hidden property. You would typically do this in the InitializeLayout event of the grid.
