Hi Infragistics Team,
I have a grid as shown below
After the column 'Type', there are two empty columns. Need to merge these two columns as shown below in the grid
Kindly assist me to achieve this solution.
Hi Thangachan,Thank you for posting in our forums.Merging works only if you have the same values in a two adjacent columns. So in this case, since you have different values in your columns, it is not really applicable. What I would suggest to do in this case is to hide the empty columns and make the “Type” column larger. You can hide a column by setting its Hidden property to true and you can control its width from the Width property: ultraGrid1.DisplayLayout.Bands[0].Columns["EmptyColumn1"].Hidden = true; ultraGrid1.DisplayLayout.Bands[0].Columns["EmptyColumn2"].Hidden = true; ultraGrid1.DisplayLayout.Bands[0].Columns["Type"].Width = 200;Please let me know if you have any additional questions.
