This is the first time I have ever worked with a chart of any kind and I am struggling a bit to find a way to do the simple things I want to do. I know there must be a property somewhere, but I have not found it. I am using a stacked column chart. The first issue that I am trying to resolve is when there are multiple data values stacked, when I hover over each area, the tooltip displays a cumulative number (a sum) as you move up the stack instead of displaying the actual data value for that area. For example, if I have a stack made up of 3 areas, the first value is 5, the second value is 10 and the third value is 5, when I hover over the bottom area, the tooltip is 5, but when I hover over the second area, the tooltip is 15. I expect this to be 10. When I hover over the third area, the tooltip is 20. I expect this value to be 5. What do I need to do to get this expected behavior? Also, I need to add some additional text to the tooltip and see that I should be able to use the FillSceneGraph method to accomplish this, but I’m having difficulty finding the primitives for the boxes that make up my stack. Is there a good tutorial somewhere that will enable me to familiarize myself with the stacked column chart and how to work with it? I have been through the forum and I’m still going through it, but thought I would go ahead and get my questions out there to see if I could get some help. Thanks, Sabrina
I do believe the items included in the context hashtable are based on the chart-type. For the Stack3DColumnChart, the DATA_VALUE is the equivalent to the DATA_VALUE_ACCUMULATED_ELEMENT of other chart-types.
Let me know if this helps.
Chris
I have modified the sample and recreated the issue and attached it here. I did fail to mention that my chart is 3D. Is that the reason I don't see DATA_VALUE_ACCUMULATED_ELEMENT? If that is the case, is there a reason why it's not included for that type of chart because it would certainly be beneficial in the 3D context as well.
Thanks, Sabrina
I got it to work. I wrote a bit of code to get the accumulated value manually.
Thanks so much for all your help. It really made all the difference in allowing me to move forward.
Hello Sabrina,
I can't see any reason that the DATA_VALUE_ACCUMULATED_ELEMENT would not exist in the context hashtable. Glancing at the code, DATA_VALUE, DATA_VALUE_ITEM and DATA_VALUE_ACCUMULATED_ELEMENT are added for all Stacked chart types. To figure out why they are not available in your application, I'd need a sample that reproduces the issue. See if you can modify the previously attached sample so it reproduces the problem.
In the debugger, the following is what I have in Context. Is the DATA_VALUE_ACCUMULATED_ELEMENT not there because of the way I am loading my table/chart? I don't see anything in the documentation that explains how I might insure that I get this value in the context hashtable. Any ideas would be greatly appreciated.
