I am using the 16.1's UltraPivotGrid against a flat data source (such as generic List of a Poco object).
I was able to programatically define the rows, columns, metrcis and filters. However, how do I save the chosen layout which means, user modified rows/columns, or state such as expanded rows, columns, etc?
This is on Winforms.
Hi Jose,
Thank you very much for sharing all this with the community! Make sure to also support the feature idea so that in the future versions this will be available automatically, without the need of implementing anything.
Here is an example of it working using the technique I explained in the earlier post
https://www.youtube.com/watch?v=8PKGK2K4nC8
Hope it helps!
In the data source you have the following events
AxisAddHierarchyAsyncCompletedAxisRemoveHierarchyAsyncCompletedAddFilterAsyncCompletedRemoveFilterAsyncCompletedAddMeasureAsyncCompletedRemoveMeasureAsyncCompleted
These get fired when the user Adds / Removes Filters, Columns and Rows
Create 4 distict lists to contain this information
List<string> measures, cols, rows, filters;
Then on each of those events add / remove accordingly
private void Ds_RemoveMeasureAsyncCompleted(object sender, Infragistics.Olap.RemoveMeasureAsyncCompletedEventArgs e) { measures.Remove(e.MeasureUniqueName); }
private void Ds_AddMeasureAsyncCompleted(object sender, Infragistics.Olap.AddMeasureAsyncCompletedEventArgs e) { measures.Add(e.MeasureUniqueName); }
private void Ds_RemoveFilterAsyncCompleted(object sender, Infragistics.Olap.RemoveFilterAsyncCompletedEventArgs e) { filters.Remove(e.HierarchyUniqueName); }
private void Ds_AddFilterAsyncCompleted(object sender, Infragistics.Olap.AddFilterAsyncCompletedEventArgs e) { filters.Add(e.HierarchyUniqueName); }
private void Ds_AxisRemoveHierarchyAsyncCompleted(object sender, Infragistics.Olap.AxisRemoveHierarchyAsyncCompletedEventArgs e) { if (e.AxisType == Infragistics.Olap.AxisType.Row) rows.Remove(e.HierarchyUniqueName); else rows.Remove(e.HierarchyUniqueName); }
private void Ds_AxisAddHierarchyAsyncCompleted(object sender, Infragistics.Olap.AxisAddHierarchyAsyncCompletedEventArgs e) { if (e.AxisType == Infragistics.Olap.AxisType.Row) rows.Add(e.HierarchyUniqueName); else rows.Add(e.HierarchyUniqueName); }
You can then serialize or (somehow) save those lists and then next time you load the Pivot you can set those in your FlatDataSourceInitialSettings()
var settings = new FlatDataSourceInitialSettings();
//Load up your rows, columns, measures and filters and create a comma separated string for each one I assume you can figure that part out yourself
settings.Rows = GetCommaSeparatedList(rows);
settings.Columns = GetCommaSeparatedList(cols);
settings.Filters = GetCommaSeparatedList(filders);
settings.Measures = GetCommaSeparatedList(measure);
Hope this helps!
Hi Riyaz,
Thank you for posting in our forums.
Currently the UltraPivotGrid doesn’t have such functionality. We have a product idea for this in our product idea site. You can find it here. What I would suggest is to upvote the idea. When planning new releases, our Product Management team will look at the most popular features and use your feedback to prioritize upcoming work.
Please let me know if you have any additional questions.
