I am plotting points in a line chart continuously, reading data from a device every second. This may go upto an hour or more.
i.e, plotting almost 3600 points every hour . The elapsed time/sample number is displayed in the X-Axis label.
After a few minutes of plotting, the X-Axis labels disappear. this is because there is no more space to display them.
I do not want to use the scroll bar and scaling.
Is it possible to modify label display at runtime ? For example, if I have a chart display area equivalent to the size of this Text box, then to start with I will display all sample numbers/elapsed time [vertically] like 1 2 3 5 6 ....
After sometime, based on the lenght of X Axis, when some number of points have been plotted, then I will start displaying only selected labels like: 1 5 10 15 20 ......
Again after some number of points are plotted, I will change to 1 10 20 30 40 ....
and then 1 20 40 ..... like this....
Is there a way to do this?
It worked.
Thanks a lot.
Regards
sanms
You can try adding the following line:
this.ultraChart1.Axis.X.Labels.Layout.Behavior = Infragistics.UltraChart.Shared.Styles.AxisLabelLayoutBehaviors.None;
Even this did not solve my problem. You can simulate it by just copying the code below and running it for some time, say for 300 seconds..
Sorry I could not insert the output graph here.
I modified your code to have a delay of 500ms before each draw. Because I get data from device based on a specified interval [say every second]
Also added 1 Second to dateTime after each draw.
private const int maxLabels = 15;
private Random rnd;
private DateTime dateTime;
public Form1()
InitializeComponent();
rnd = new Random();
protected override void OnLoad(EventArgs e)
base.OnLoad(e);
NumericTimeSeries series = new NumericTimeSeries();
this.dateTime = DateTime.Now;
this.ultraChart1.Series.Add(series);
this.ultraChart1.Axis.X.TickmarkIntervalType = Infragistics.UltraChart.Shared.Styles.AxisIntervalType.Seconds;
this.ultraChart1.Axis.X.TickmarkStyle = Infragistics.UltraChart.Shared.Styles.AxisTickStyle.DataInterval;
System.Windows.Forms.Timer timer1 = new Timer();
timer1.Interval = 500;
timer1.Tick +=new EventHandler(timer1_Tick);
timer1.Start();
private void timer1_Tick(object sender, EventArgs e)
NumericTimeSeries series = this.ultraChart1.Series[0] as NumericTimeSeries;
NumericTimeDataPoint dataPoint = new NumericTimeDataPoint(this.dateTime, rnd.Next(100), dateTime.ToString(), false);
series.Points.Add(dataPoint);
int count = series.Points.Count;
this.ultraChart1.Axis.X.TickmarkInterval = count / maxLabels;
dateTime = dateTime.AddSeconds(1);
In this case the code can be something like:
public partial class Form1 : Form
Only difference is that I have to plot against time [ show date time as X - Axis label]
I am having problem if I have to display datavalues against time. Whatever problem I have is with Linechart displaying Date Time in X-Axis as label [ Instead of XYSeries and XYDataPoint Am using NumericTimeSeries and NumericDataPoint respectively ]
Is it possible to have Scatter chart displaying DateTime as labels...
I am using 8.1 version
In the code below I have tried to reproduce the problem
private Random rnd; System.Windows.Forms.Timer timer1;public Form1() { InitializeComponent();rnd = new Random(); ultraChart1.ChartType = Infragistics.UltraChart.Shared.Styles.ChartType.LineChart;ultraChart1.LineChart.TreatDateTimeAsString = true;ultraChart1.Axis.X.TickmarkStyle = Infragistics.UltraChart.Shared.Styles.AxisTickStyle.DataInterval; ultraChart1.Axis.X.TickmarkInterval = 2;ultraChart1.Axis.X.Labels.ItemFormatString = "<ITEM_LABEL>"; }protected override void OnLoad(EventArgs e) { base.OnLoad(e);NumericTimeSeries series = new NumericTimeSeries(); for (int i = 0; i <= 5; i++) {System.Threading.Thread.Sleep(500);NumericTimeDataPoint point = new NumericTimeDataPoint(DateTime.Now, rnd.Next(100), DateTime.Now.ToShortTimeString(), false); series.Points.Add(point); this.ultraChart1.Series.Add(series);this.ultraChart1.Refresh(); } ultraChart1.Axis.X.TickmarkInterval = 5; int count = series.Points.Count;for (int i = 1; i <= count + 20; i++) {System.Threading.Thread.Sleep(500); RepeatDraw(); } ultraChart1.Axis.X.TickmarkInterval = 10; timer1 = new Timer(); timer1.Interval = 100;timer1.Tick += new EventHandler(timer1_Tick); timer1.Start(); }private void RepeatDraw() { NumericTimeSeries series = this.ultraChart1.Series[0] as NumericTimeSeries;NumericTimeDataPoint point = new NumericTimeDataPoint(DateTime.Now, rnd.Next(100), DateTime.Now.ToShortTimeString(), false); series.Points.Add(point); this.ultraChart1.Series.Add(series);this.ultraChart1.Refresh(); }private void timer1_Tick(object sender, EventArgs e) { NumericTimeSeries series = this.ultraChart1.Series[0] as NumericTimeSeries; int count = series.Points.Count;for (int i = 1; i <= count + 200; i++) { NumericTimeDataPoint point = new NumericTimeDataPoint(DateTime.Now, rnd.Next(100), DateTime.Now.ToShortTimeString(), false); series.Points.Add(point);this.ultraChart1.Series.Add(series);this.ultraChart1.Refresh(); } timer1.Stop(); }
RepeatDraw();
timer1.Stop();
