250
Proper Resizing of WinDockManager Control at any DPI
When a WinDockManager  control is resized due to the DPI setting (for example resizing from 100% to 150% or 200%), the WinDockManager  left panel is not changed. This results in the fixed panel appearing too large and cut off.
This issue is similar to the problem discussed with regard to the splitter control in the following blog:
http://www.codeproject.com/Tips/786170/Proper-Resizing-of-SplitterContainer-Controls-at-a
Do you have a fix that resolves the issue? I am currently using V14.1 (14.1.20141.2059).
