1660
Wingrid with dropdown having different datasource
We have a wingrid with 2 level bands. Level 0 - parent, Level 1 - Child. Child has 2 columns. Based on the column 1 the column 2 dropdown should be loaded. Earlier we have done this in web based. Here we are not able to use the javascript function. Need help on which event will have the row datakeyfield and how to load the datasource to the dropdown. Sample coding as follows.
Loading Grid:
DataSet dsMenus = new DataSet();
DBHelper.DLConnect dl = new DLConnect();
try
string sSQL = "Query ";
dsMenus = dl.ExecuteDataSet(sSQL);
DataRelation relChildClass1 = new DataRelation("MenuLevel1", dsMenus.Tables[0].Columns[MENU_KEY], dsMenus.Tables[1].Columns[MENU_PARENT_KEY]);
dsMenus.Relations.Add(relChildClass1);
roles_Grid.DataSource = dsMenus;
roles_Grid.Rows.CollapseAllCards();
roles_Grid.DisplayLayout.AutoFitStyle = Infragistics.Win.UltraWinGrid.AutoFitStyle.ResizeAllColumns;
Initialize Row:
e.Layout.Bands[0].Columns[MENU_KEY].Hidden = true;
e.Layout.Bands[1].Columns[ROLE_MENU_KEY].Hidden = true;
e.Layout.Bands[1].Columns[CREATED_BY].Hidden = true;
e.Layout.Bands[1].Columns[CREATED_DATE].Hidden = true;
e.Layout.Bands[1].Columns[LAST_MODIFIED_BY].Hidden = true;
e.Layout.Bands[1].Columns[LAST_MODIFIED_DATE].Hidden = true;
e.Layout.Bands[0].Columns[MENU_NAME].CellActivation = Infragistics.Win.UltraWinGrid.Activation.NoEdit;
e.Layout.Bands[0].Columns[MENU_NAME].Header.Caption = "Module";
e.Layout.Bands[1].Columns[MENU_KEY].Hidden = true;
e.Layout.Bands[1].Columns[MENU_PARENT_KEY].Hidden = true;
e.Layout.Bands[1].Columns[MENU_NAME].CellActivation = Infragistics.Win.UltraWinGrid.Activation.NoEdit;
e.Layout.Bands[1].Columns[MENU_NAME].Header.Caption = "Sub Module";
e.Layout.Bands[1].Columns[ACCESS_TYPE_KEY].CellActivation = Infragistics.Win.UltraWinGrid.Activation.AllowEdit;
e.Layout.Bands[1].Columns[ACCESS_TYPE_KEY].Style = Infragistics.Win.UltraWinGrid.ColumnStyle.DropDownList;
e.Layout.Bands[1].Columns[ACCESS_TYPE_KEY].Band.Columns.Cast();
e.Layout.Bands[1].Columns[ACCESS_TYPE_KEY].Header.Caption = "Access Type";
e.Layout.AutoFitStyle = AutoFitStyle.ResizeAllColumns;
//e.Layout.Bands[0].ColHeadersVisible = true;
//e.Layout.Bands[1].ColHeadersVisible = true;
  • 21795
    Verified Answer
    Hello Thangachan,
    If I understand you correctly you have hierarchical grid, for which you need to add conditionally drop downs to the cells in a particular column in the second band. You can achieve this by handling InitializeRow event of the grid. In this event you can check if the row is in the child band. if so check the value of the cell on which the dropdown values depends. Created the dropdown depending on the cell value and add it to the cell where the dropdown should appear. You may use code like this:
    private void UltraGrid1_InitializeRow(object sender, InitializeRowEventArgs e)
        // if the row reinitialize just exit the event as dropdowns should be already set
        if (e.ReInitialize)
            return;
        // if the band index is 1 this is the child band so set the dropdowns
        if (e.Row.Band.Index == 1)
            // get a reference to the cell in current row where the dropdown will be added
            var dropdownCell = e.Row.Cells["Name"];
            // set the style of the cell
            dropdownCell.Style = Infragistics.Win.UltraWinGrid.ColumnStyle.DropDownList;
            // create a VlueList which later will be populated with values according to firs cell value
            var vl = new ValueList();
            // set the ValueList as drop down cell value list
            dropdownCell.ValueList = vl;
            // depending on the value in first cell add different items to drop down
            switch (e.Row.Cells["id"].Text)
                case "0":
                    vl.ValueListItems.Add("Microsoft");
                    vl.ValueListItems.Add("Lumia");
                    vl.ValueListItems.Add("Surface");
                    break;
                case "1":
                    vl.ValueListItems.Add("Apple");
                    vl.ValueListItems.Add("iPhone");
                    vl.ValueListItems.Add("iPad");
                    break;
                case "2":
                    vl.ValueListItems.Add("Samsung");
                    vl.ValueListItems.Add("Galaxy");
                    vl.ValueListItems.Add("Galaxy Tab");
                    break;
    Please check the attached sample project where I have implement this approach and let me know if you need any additional information.
    CAS-171448-W6C6T6.zip
