25
Cannot stop others section appearing in pie chart
Hi i have read earlier posts that say to set the OthersCategoryPercent = 0 to stop the others section from appearing on a pie chart. I have added this into my code and it does not seem to have an effect. I am using a composite chart if this makes a difference.
I have made a sub which populates the values and creates the chart on the form
when i use the data, the chart is fine with no to others section
PickStatusOrders_Pie(10, 50, 37, 29, 8)
i do not get the others section
when i use the following data the others section appears
PickStatusOrders_Pie(56, 88, 42, 44, 6)
I added the line
Me.UltPickStatusPieChart.PieChart.OthersCategoryPercent = 0
in the hope this would make sure all values where always shown but it does not seem to have an effect.
Is there something i am missing?
Ian
My code is below
Imports Infragistics.Win.UltraWinGrid
Imports Infragistics.UltraGauge.Resources
Imports Infragistics.UltraChart.Shared.Styles
Imports Infragistics.UltraChart.Resources.Appearance
Imports Infragistics.UltraChart.Core.Layers
  Private Sub PickStatusOrders_Pie(ByVal NotReleasedValue As Integer, _
                                     ByVal ReleasedValue As Integer, _
                                     ByVal PickingValue As Integer, _
                                     ByVal DespatchedValue As Integer, _
                                     ByVal CancelledValue As Integer)
        Try
            Me.UltPickStatusPieChart.CompositeChart.ChartAreas.Clear()
            Me.UltPickStatusPieChart.CompositeChart.ChartLayers.Clear()
            Me.UltPickStatusPieChart.CompositeChart.Legends.Clear()
            Me.UltPickStatusPieChart.CompositeChart.Series.Clear()
        Catch
        End Try
        'stop lowest data values being grouped in 'others' Category
        'set chart type
        Me.UltPickStatusPieChart.ChartType = ChartType.Composite
        'add new area
        Dim myChartArea As New ChartArea()
        Me.UltPickStatusPieChart.CompositeChart.ChartAreas.Add(myChartArea)
        'get data for chart
        Dim mySeries As New NumericSeries()
        mySeries.Label = "Pick Status"
        mySeries.Points.Add(New NumericDataPoint(NotReleasedValue, "NotReleased", False))
        mySeries.Points.Add(New NumericDataPoint(ReleasedValue, "Released", False))
        mySeries.Points.Add(New NumericDataPoint(PickingValue, "Picking", False))
        mySeries.Points.Add(New NumericDataPoint(DespatchedValue, "Despatched", False))
        mySeries.Points.Add(New NumericDataPoint(CancelledValue, "Cancelled", False))
        'add series
        Me.UltPickStatusPieChart.CompositeChart.Series.Add(mySeries)
        'add appearances
        Dim myColumnLayer As New ChartLayerAppearance()
        myColumnLayer.ChartType = ChartType.PieChart
        myColumnLayer.ChartArea = myChartArea
        myColumnLayer.Series.Add(mySeries)
        Me.UltPickStatusPieChart.CompositeChart.ChartLayers.Add(myColumnLayer)
        ' add legend
        Dim myLegend As New CompositeLegend()
        myLegend.ChartLayers.Add(myColumnLayer)
        myLegend.Bounds = New Rectangle(0, 75, 20, 25)
        myLegend.BoundsMeasureType = MeasureType.Percentage
        myLegend.PE.ElementType = PaintElementType.Gradient
        myLegend.PE.FillGradientStyle = GradientStyle.ForwardDiagonal
        myLegend.PE.Fill = Color.CornflowerBlue
        myLegend.PE.FillStopColor = Color.Transparent
        myLegend.Border.CornerRadius = 10
        myLegend.Border.Thickness = 0
        Me.UltPickStatusPieChart.CompositeChart.Legends.Add(myLegend)
    End Sub
