510
UltraTree checkbox column & spacebar key
I have a node with a check-box column. When the column has focus (activated) I want the user to use the spacebar key to toggle the state of the chekbox.
This is how I setup the column:
_checkEditor = new UltraCheckEditor();
 _checkEditor.CheckAlign = ContentAlignment.MiddleLeft;
_fixBatchColumnSet = new UltraTreeColumnSet();
_fixBatchColumnSet.Columns.Add("Active");
_fixBatchColumnSet.Columns["Active"].EditorComponent = _checkEditor;
_fixBatchColumnSet.Columns["Active"].HeaderAppearance.TextHAlign = HAlign.Left;
_fixBatchColumnSet.Columns["Active"].AllowCellEdit = AllowCellEdit.Full;
Is this possible?
  • 6120
    Hi Joseph,
    To achieve this you have to write custom code in your KeyUp event that checks if the active key is a SpaceBar key and if it is then toggle the check-box column value.
    Is there a specific reason why you are using UltraTree control because you can use our UltraGrid Control which does this automatically for you?
    Sincerely,
    Sahaja Kokkalagadda
    Associate Software Developer, Windows Forms
    http://es.infragistics.com/
