405
Multi-select combo column in ultragrid
I have an ultragrid that is bound to a binding list of objects. The object has a public property that is a list of another object.
Is there anyway for me to display that property in the grid as a column with a multi-select dropdown/combo displaying the property values.
I know the grid by default will set this public property as a child band, but can it be set to be displayed as a column with values being comma separated?
I am aware that ultragrid allows you to set the editor component of a column to an external control, but I was wondering if someone has done something like this before?
Since the grid is bound to the binding list and I'm using PetaPoco, if I can get the objects property to be bound to the column and update automatically, it will make saving the object much easier and simpler for me.
Karthik
