4032
UltraTree Designer Error after Upgrade 2015.2.2023
I have upgraded my visual studio 2012 project (windows forms) from 2014.2 to 2015.2.2023. After that my program was running ok. But editing a form with ultra tree and some desingtime nodes, I got some designer syntax error. If I delete this rows manually and copy it from backup, the errors are generated again.
The error lines looks like this (see the while tree section attached):
            resources.ApplyResources(ultraTreeNode1.1, "ultraTreeNode1.1");
            resources.ApplyResources(ultraTreeNode1.2, "ultraTreeNode1.2");
            resources.ApplyResources(ultraTreeNode1.0, "ultraTreeNode1.0");
            resources.ApplyResources(ultraTreeNode1.4, "ultraTreeNode1.4");
            resources.ApplyResources(ultraTreeNode1.5, "ultraTreeNode1.5");
            resources.ApplyResources(ultraTreeNode1.6, "ultraTreeNode1.6");
            resources.ApplyResources(ultraTreeNode1.3, "ultraTreeNode1.3");
            resources.ApplyResources(ultraTreeNode1.8, "ultraTreeNode1.8");
            resources.ApplyResources(ultraTreeNode1.7, "ultraTreeNode1.7");
Is this a bug in Ultra Tree? What can I do to solve this?
Regards
Markus
UltraTree.Designer.zip
  • 21795
    Hello Markus,
    I have investigated your issue, and I have asked our engineering staff to examine “Designer adds wrong code in localized form” further. To ensure that it will receive attention, I have logged this behavior in our internal tracking system with a Development ID of #211656. So I’ve created a case for you CAS-168193-J3R8H5 and will update you for the progress of this issue via the mentioned case. You could reach your case following the link below:
    https://es.infragistics.com/my-account/support-activity
