230
BubbleChart - Bubble Diameter Ratios
Hi
We're using a winforms bubble chart. My understanding was the diameter of each bubble should be proportional to its value  and all other bubble values. By this I mean if one bubble had a value of 4 and the other 8 then the 8 bubble would have twice the diameter of the 4 bubble - but this isn't the case on our chart i.e. a bubble having a value of  111,100.00 has a diameter one third the size of a bubble with value 236,700.00
Could you please put me right on this.
  • 21795
    Hello Anton,
    I have investigated your issue, and I have asked our engineering staff to examine “The smallest bubble is not drawn with correct size” further. To ensure that it will receive attention, I have logged this behavior in our internal tracking system with a Development ID of #210311. So I’ve created a case for you CAS-167141-F3W6H1 and will update you for the progress of this issue via the mentioned case. You could reach your case following the link below:
    https://es.infragistics.com/my-account/support-activity
