We recently upgraded to version 14.2.20142.2168. I have many .resx files that still have 14.2.20142.2010. My development environment works ok but our deployed run time is producing errors. Why do the .resx files still have 2010 in them? why is this causing an error at run time but not in our development environment? Do I need to get all the .resx files to have 2168? How do I do this without manually editing each one? We are using Progress 11.5.1.011 64 bit for our development products.
System.ArgumentException: ResX file Type Infragistics.Win.SpinButtonDisplayStyle, Infragistics4.Win.v14.2, Version=14.2.20142.2010, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb in the data at line 2615, position 4 cannot be located. Line 2617, position 5. cannot be parsed.
System.Xml.XmlException: Type Infragistics.Win.SpinButtonDisplayStyle, Infragistics4.Win.v14.2, Version=14.2.20142.2010, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb in the data at line 2615, position 4 cannot be located. Line 2617, position 5.
System.TypeLoadException: Type Infragistics.Win.SpinButtonDisplayStyle, Infragistics4.Win.v14.2, Version=14.2.20142.2010, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb in the data at line 2615, position 4 cannot be located.
System.Xml.XmlException: Type Infragistics.Win.SpinButtonDisplayStyle, Infragistics4.Win.v14.2, Version=14.2.20142.2010, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb in the data at line 2615, position 4 cannot be located. Line 2615, position 4.
Hello Larry,
I'm wondering if you were able to solve your issue, or you still need an assistance on the matter?If you still need any help, it would be nice to provide an information for the questions above. That will help us investigate the described behavior, and help you as soon as possible.
I have some questions for your project.
