Hi all!
After upgrading from 15.1 to 15.2 we have serious Problems with one of our grid.
The grid have 3 Groups and in 1 Group a summary.
Me.Grid_Calender.DisplayLayout.Bands(0).Groups.Add("TimeDiffe")
Me.Grid_Calender.DisplayLayout.Bands(0).Groups("TimeDiffe").Columns.Add(.Columns("TimeDiffMinutes"))
Me.Grid_Calender.DisplayLayout.Bands(0).Groups("TimeDiffe").Columns.Add(.Columns("TimeDiffHours"))
Me.Grid_Calender.DisplayLayout.Bands(0).Groups("TimeDiffe").Header.Caption = "Difference to Time model"
Me.Grid_Calender.DisplayLayout.Bands(0).Groups("TimeDiffe").Header.Appearance.BackColor = Color.FromArgb(67, 168, 152)
.SummaryFooterCaption = "Time difference in minutes"
.Override.SummaryDisplayArea = UltraWinGrid.SummaryDisplayAreas.TopFixed
.Override.SummaryFooterAppearance.FontData.Bold = DefaultableBoolean.True
.Summaries.Add("TimeDiffTotal", UltraWinGrid.SummaryType.Sum, .Columns("TimeDiffMinutes"), UltraWinGrid.SummaryPosition.UseSummaryPositionColumn)
.Summaries("TimeDiffTotal").DisplayFormat = "{0:#,##0}" & " m"
.Summaries("TimeDiffTotal").Appearance.TextHAlign = HAlign.Right
.Summaries.Add("TimeDiffHours", UltraWinGrid.SummaryType.Sum, .Columns("TimeDiffHours"), UltraWinGrid.SummaryPosition.UseSummaryPositionColumn)
.Summaries("TimeDiffHours").DisplayFormat = "{0:#,##0.00}" & " h"
.Summaries("TimeDiffHours").Appearance.TextHAlign = HAlign.Right
This code worked well in 15.1. Now we got follwoing error:
system.NullReferenceException: Object reference not set to an instance of an object. at Infragistics.Win.UltraWinGrid.UltraGridGroup.AlignHeaderInFixedHeaderArea(Rectangle& headerRect, Rectangle& fixedHeaders, BandHeaderMetricsCache bandHeaderMetricsCache) at Infragistics.Win.UltraWinGrid.UltraGridGroup.CalculateHeaderRect(Rectangle& headerRect, Rectangle& fixedHeaderRect, BandHeaderMetricsCache bandHeaderMetricsCache) at Infragistics.Win.UltraWinGrid.UltraGridColumn.CalculateHeaderRect(Rectangle& rcHeader, Rectangle& prcFixedHeaders, BandHeaderMetricsCache bandHeaderMetricsCache) at Infragistics.Win.UltraWinGrid.FixedSummaryLineUIElement.GetSummaryLocation(UltraGridColumn column, Int32& x, Int32& width) at Infragistics.Win.UltraWinGrid.FixedSummaryLineUIElement.PositionChildElements() at Infragistics.Win.UIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive) at Infragistics.Win.UIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive) at Infragistics.Win.UIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive) at Infragistics.Win.UIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive) at Infragistics.Win.UltraWinGrid.RowColRegionIntersectionUIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive) at Infragistics.Win.UIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive) at Infragistics.Win.UltraWinGrid.DataAreaUIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive) at Infragistics.Win.UIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive) at Infragistics.Win.UltraWinGrid.UltraGridUIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive) at Infragistics.Win.UIElement.VerifyChildElements(Boolean recursive) at Infragistics.Win.UltraWinGrid.UltraGridLayout.GetUIElement(Boolean verify, Boolean forceInitializeRect) at Infragistics.Win.UltraWinGrid.UltraGrid.OnPaint(PaintEventArgs pe) at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer) at System.Windows.Forms.Control.WmPaint(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
The Group only work well and also only the summary work well.
But not togeter....any ideas?
rgds
Thank you for pointing to the other thread. I was able to find out the development issue tied and determined that the issue has been fixed but not released to the public. However the next service release will be some time in December. Let me know if you have any concerns about this.
Well, your sample works for me too.
But I found a Workaround here:
http://es.infragistics.com/community/forums/t/103112.aspx
The error occurs only, if the Summary is set to the LAST column in the grid, after adding a new column behind, my code works also (must ot be set to Hidden = true)
And as I wrote, 15.1 worked well before!
I started working on a sample but haven't been able to reproduce the exception. Would you mind reproducing the behavior; I've attached the sample here.
Let me know if you have any questions regarding this matter.
P.S.:
If I canges the Position if the Summaries from UseSummaryPositionColumn to Right it works, but I have to display 2 summaries and changing it to right Shows only one
