Is it possible to change spacing between two labels rows inside a legend of an ultrachart. I wanted to increase the vertical spacing between two label rows inside the legendn as its inadequate and the two labels rows are nearly getting merged.
Thanks in advance
works fine for me as well. what (4-part) version number is the dll you're using? maybe downloading the latest hotfix will resolve this problem.
I'm using a column chart
Which chart type you are using? I've been trying your code with ColumnChart and it seems to work.
I looked at the item you referenced however it did not actually address my question.
You can try looking at:
http://news.infragistics.com/forums/p/5297/23905.aspx#23905
