Is there anyway to display the dialog, in run mode, that displays in the designer when you click the right button in the "value" property?
Thanks that worked.
The class is Infragistics.Win.SupportDialogs.FormattedTextEditor.FormattedTextUIEditorForm, so you would need to add a reference to the "Infragistics2.Win.SupportDialogs" assembly.
-Matt
