I have created a ribbon using WinToolBar in my application. I am using the font Segoe UI, 8pt which is Microsoft Standard for ribbon for Office 2007. When i view run my application. The ribbon still does not look same as Office 2007 ribbon. The fonts are not clear as in Office 2007 ribbon. How can active the similar look. My System is XP.
RegardsSumit Kute
The text could be blurry because you have ClearType font smoothing enabled and perhaps Word is disabling this somehow. You can try to turn this off or to set the TextRenderingMode of the UltraToolbarsManager to GDI.
As for the space above the tool tip title, this is a bug. You can submit this to the support group here: http://es.infragistics.com/gethelp.
Click as shown in the image below.. to see the image clearly.
The image got dissorted after attachedment. I cannot attached a BMP file.
Please find the image.
Problems.
1) The Tool Caption I have used is not clear as word 2007.
2) The tooltipformatted which i have specified are also as clear as in worrd 2007
3) The tooltipTitle is not leaving any space at the top as in Word 2007.
I want my screentips(tooltip) text, tool caption are not looking same as word 2007.
Select the options tab when composing your reply. It has a button to add an attachment.
