545
Problem with the alignment of the legend
hello,
I have a simple view consists of a graph and a legend below it.
For simplicity I have highlighted in red the frame of the legend
The problem is that values are centered, but remain aligned in the upper right
Below I put the code and an image:
    IGChartView *grafico = [[IGChartView alloc] init];
    grafico.translatesAutoresizingMaskIntoConstraints = NO;
    grafico.delegate = self;
    [self.view addSubview:grafico];
    IGLegend *legend = [[IGLegend alloc] initWithLegendType:IGChartLegendTypeSeries];
    legend.translatesAutoresizingMaskIntoConstraints = NO;
    legend.orientation = IGOrientationHorizontal;
    legend.horizontalAlignment = IGHorizontalAlignCenter;
    legend.verticalAlignment = IGVerticalAlignCenter;
    legend.backgroundColor = [UIColor redColor];
    grafico.legend = legend;
    [self.view addSubview:legend];
    //Constraints
    NSDictionary *views = NSDictionaryOfVariableBindings(grafico,legend);
    [self.view addConstraints:[NSLayoutConstraint constraintsWithVisualFormat:@"H:|[grafico]|" options:0 metrics:nil views:views]];
    [self.view addConstraints:[NSLayoutConstraint constraintsWithVisualFormat:@"H:|[legend]|" options:0 metrics:nil views:views]];
    [self.view addConstraints:[NSLayoutConstraint constraintsWithVisualFormat:@"V:|[grafico][legend(50)]|" options:0 metrics:nil views:views]];
Parents
No Data
Reply
  • 26458
    Hi Mattia,
    The problem has been fixed and is currenly undergoing testing for future service release.
    I just wanted to let you know that if you need a workaround that still uses layout constraints you can do the following:
    Create a custom legend that derives from IGLegend and override setBounds. Something like this:
    @interface CustomLegend : IGLegend
    @end
    @implementation CustomLegend
    -(void)setBounds:(CGRect)bounds
        [super setBounds:bounds];
        [self updateItems];
    @end
    You would then replace your IGLegend with CustomLegend and the alignment will work properly
Children
No Data
