20
Changing color of days in month view
I want to change the color of background in month view is it possible in igcalendarview ?
Here is the screenshotSample
Parents
No Data
Reply
  • 21382
    Suggested Answer
    Helo Alekh,
    There isn't an easy way to do this at this time in the product.  I have added a suggestion in our suggestion system for this to be added as a feature in the future.  If you could go to this link
    http://ideas.infragistics.com/forums/211525-nuclios/suggestions/6699032-calendar
    And vote for the idea, when the product managers go through the ideas they can see which customers would like the feature.
    However there is a workaround which you could use, but it would be a bit clunky.
    If you implement the IGCalendarViewDelegate and subsequently the following method
    -(void)calendarView:(IGCalendarView *)calView monthChanged:(NSDate *)date
    Then you would be able to jump into the visual model and modify the colors directly.  If you navigate to the month view from the year view, all will look well.  If you scroll from month to month in the view however, the days won't color until the full month is shown as that is when the method is raised internally.   As I said this is a work around.
        UIView* multiMonthView = [_cal valueForKey:@"_monthView"];
        Class c = NSClassFromString(@"DateInfo");
        id dateInfo = objc_msgSend(c, @selector(resolveInfoForDate:usingCalendarView:), date, calView);
        UIView* monthView = objc_msgSend(multiMonthView, @selector(resolveMonthViewForDate:), dateInfo);
        int howManyDaysInMonth = objc_msgSend(dateInfo, @selector(numberOfDays));
        for (int i = 1; i <= howManyDaysInMonth ; i++)
            objc_msgSend(dateInfo, @selector(setCurrentDay:), i);
            UIView* monthViewDay = objc_msgSend(monthView, @selector(resolveMonthViewDayForDate:), dateInfo);
            monthViewDay.backgroundColor = [UIColor clearColor];
            if (i>15 && i<22)
                monthViewDay.backgroundColor = [UIColor orangeColor];
Children
No Data
