Is there a way to force the legend to display all items that are represented in a pie chart even if the item has a zero value? I'm comparing 2 months of data and I want both pie charts to display the same legends. I also need both pie charts to use the same colours for the same items. Right now when I compare a chart with 2 items to one that has 1 item, the colours don't match. Both chart's item 1 are the same colour however item 1 on the second chart should match item 2 on the first chart. Any help would be appreciated.
Hello ,
This was logged as new product idea and you could vote for it or add comments on the following link:
http://ideas.infragistics.com/forums/211525-nuclios/suggestions/6589799-display-all-items-when-there-is-a-zero-value-with
Is there any update on this feature?
Great. Thank you. Keep us posted.
Hello Ostrem,
The behavior you are seeing is the designed behavior. Since the value is zero, it's excluded and then the color isn't used.
It sounds like a decent feature request however, so I will add it to our backlog to see if we can get it into the product.
