1615
Multi Column DSH
I have a multi column DSH grid. I would like all cells to be keep the same size regardless of landscape/portrait orientation.
Right now cells seem to resize when I rotate. How can I ensure constant and predetermined size for all cells ?
  • 40030
    Verified Answer
    By default Column widths are not fixed size. Instead they equally size to fit within the grid's viewport.
    To change this, you simply just need set the ColumnWidth property on  either the IGGridView or IGGridViewColumnDefinition you're using.
    grid.ColumnWidth = IGColumnWidth.CreateNumericColumnWidth (200);
    -SteveZ
