Can anyone help me out to develop sparkline which uses column series ?
Please provide me code snippet to develop sparkline view.
Thanks..
No there isn't a delegate method that would do that for the sparkline. The sparkline is designed to be pretty stripped down.
Yes darrell you are absolutely right. Actually i have read this properties in api. But my question is i want to set x-axis and y-axis in sparkline seires.
Because i refereed api for sparkline, however i didn't found any method for add axes in sparkline series.
Is there any delegate method in sparkline series like IGChartView having
- (NSString *)chartView:(IGChartView *)chartView labelForAxis:(IGAxis *)axis withItem:(NSObject *)item
for setting x and y axis label ?
Thanks.
If you want to set a different brush for the negative and positive values you would need to set the .brush and .negativeBrush properties.
Hello Darrell,
The demo is working perfectly.
But my question is can i set x-axis and y-axis in sparkline series as we have in column series in IGCategoryDataSourceHelper ?
Because my ultimate goal is, i want to display column series which have two values. i.g. +ve, and -ve with different colour.
Please give me some suggestion.
Thank you so much Darrell
