785
Using IGGridViewDataSourceHelperLoadMoreDelegate and IGGridViewDelegate.ResolveSectionHeaderView
Hey - I've attached a sample project to explain this a little better, but essentially what I'm having an issue with is when the grid goes out and does a LoadMore rows, the SectionHeaderView is being redrawn but then when I scroll back up it remains in the middle of the grid.
I was wondering what you think I'm doing wrong.
SimpleGrid.zip
  • 40030
    Verified Answer
    That is strange. From what i can tell, it appears to be a timing issue.  As a workaround, if you call UpdateData in a beginInvoke call, it gives the section header enough time to update. I've updated a code snippet below and my changes are in bold.
    public override void LoadMoreRows (IGGridViewDataSourceHelper dataSource)
                    mClinicNavigatorViewController.mPage++;
                    if (mClinicNavigatorViewController.lstGridItems.Count > 0) {
                        mClinicNavigatorViewController.lstGridItems.InsertRange (mClinicNavigatorViewController.lstGridItems.Count, LoadMorePendingDocuments ());
                        //Rebind the datasource
                        dataSource.Data = mClinicNavigatorViewController.lstGridItems.ToArray ();
                        //Update the display
                        this.BeginInvokeOnMainThread (() => {
                            gridView.UpdateData ();
    Let me know if that helps.
    -SteveZ
