Hi - When I bind a dynamically created column and use the IGGridViewDataSourceHelper.GroupKey together the grid no longer generates properly.
I've attached a sample project.
How do I use both dynamically created data and be able to group on a particular column?
That's b/c the grouping can't resolve. Setting the value to "Motion" tells the data source to look for a property called Motion on your data object. However your data object doesn't even expose any properties.
The easiest solution for you would simply to be to add a grouping property to your cSimpleGrid object:
[Export("group")] public string Group { get { return this["Motion"].ToString(); } }
Then you would set the grouping key to be "group"
dsh.GroupingKey = "group";
It's very important that you export that property. And also to use whatever value you use for the export as the GroupingKey.
It's worth noting, that while i hardCoded "Motion" into the data object, you wouldn't necessarily have to do that. The grouping key could be a value you pass into the ctor of cSimpleGrid so that it could be more by dynamic.
Hope this helps.
-SteveZ
