I am using two different series in single IGChartView.
1) is IGColumnSeries and 2) is IGStackedColumnSeries.
Now problem is i couldn't apply two different series in single chart view. When i applied, it displayed some unnecessary white space between y-axis and its label. I have taken same axis for both series and set different keys for both of axis.
Is there any way to do this ?
Thanks..
Hi Dave,
I extremely sorry for previous post. Actually the older framework of infragistics didn't remove properly and didn't replace by new one which has fixes.
So now it works perfectly.
Thank you so much for this fix. Good support by your team thanks.
I have refereed your demo. You absolutely correct when you go with two IGColumn series.
However in my case, i have used two different series to draw a chart i.e.
1) IGColumnSeries
2) IGStackedColumnSeries
So issue is still persist. kindly refer previous post.
Please resolved this issue as soon as possible.
Thanks.
Hello Kosta,
Thank you for you response.
There is no Service Release later than May 9th. I created the attached sample project to test the issue with. If you swap lines 64 and 65 in DCViewController.m you will see that the order in which the series are drawn changes.
Please note that after installing the Service Release you may need to remove and add the IGChart framework reference.
Hi Dave
I cannot access the service release on my account.
The one that is available to me is of date 9th May 2014 under the name NUCLiOS 2014 Vol. 1 - Service Release
That one does not fix this issue.
Where can I access the service release for 13th May?
Regards
Kosta
P.S. Manish and Me work for the same team.
We bought Nuclios from my account.
Hello Manish,
This issue has been resolved in the latest Service Release for Nuclios as of May 13, 2014. You can download the Service Release from the Keys & Downloads page of our web-site.
