What is the right way of setting extent property on X Axis. Right now for some of the results in my Bar chart the XAxis does not seem to fit in the view (I can only see the top of the axis). This currently happens when the bar chart has only three values. The ranges on the X Axis are decimals from -1 to 1. The chart works ok when there are 6 bars.
Hello Aleksandr,
Thank you for contacting Infragistics.
I was not able to reproduce the issue you described. I've attached the sample I created to test the issue. I'd like you to take a look at my sample and see if you can modify it so it reproduces the issue.
