85
Documentation: 2013 Vol 2 Api documentation does not show up in Xcode API help
I installed Vol 2 (after installing Vol 1 in the past). Installation is ok other than this one issue, in Xcode API help, I don't see any of the new Vol 2 components API reference help ( i.e. IGTreemapView ). Old components help ( i.e. IGChartView ) show ok. I done quite a few Xcode restarts...
It seems as the file is pointing to the correct location ( and there is only one of those links...):
lrwxr-xr-x 1 root wheel 76 Dec 9 16:44 ./Xcode.app/Contents/Developer/Documentation/DocSets/com.infragistics.IG.docset -> /Developer/Infragistics/NucliOS 2013 Volume 2/API/com.infragistics.IG.docset
Any idea?
regards,
Aviv
  • 4940
    Hi Aviv,
    Looking into the issue you reported, I confirmed that the documentation you are seeing is indeed 2013 Volume 2, but for some unknown reason it is missing the IGTreemapView API. I've logged the issue in our system with a reference number 159751 so that the issue can be resolved in an upcoming service release.
    As a possible work around, you can open the IGTreemapView.h or any of the publicly exposed header files for API comments. I apologize for the inconvenience.
