The labels in the PieChart are not fitted correctly when they are on the right side of the screen, however they are properly aligned when they are on the left side of the screen. Is this how it´s supposed to work? Or am I missing some configuration? I´ve set the property _infraPieChart.labelsPosition = IGLabelsPositionBestFit;
I´m attaching to images that show both behaviors:
Thanks in advance!
Matias,
I have submitted this issue to our developers for further review. To ensure that it will receive attention I have logged this behavior in our internal tracking system with a Development ID of 155312. A support case has also been opened for you with reference number CAS-125118-K2B4R3. You will receive more information regarding this case through the support case.
Thanks for your reply, i´ll try with the radius setting and wait for the developer´s review.
I will submit this to our developers for further review. In the meantime you could try reducing the radius of the chart so that it takes up less space.
pieChart.radiusFactor = .5, for example will reduce it by half.
