785
Implementing Pull Down to Reload and Load More Rows on Demand
Hi - I'm implementing both features mentioned above in one grid. The problem I am having is that when I implement the Pull Down to Reload feature it is making an addtional call out to the  IGGridViewDataSourceHelperLoadMoreDelegate.LoadMoreRows method. In other words when my view controller loads its making a call out to LoadMoreRows and I don't want it too and it's happening when I am implementing the Pull down to refresh feature.
If I comment out the:
//Set the overridden delegate to implement pull down to refresh.
gridView.Delegate = new gridViewDelegate (this);
Then everything works fine on the LoadMoreRows.
Not sure if my ordering of code is not right or if I need to combine these. Can you assist, below are some of my code snippets.
GRIDSETUP:
            //Next implement the load more helper
            dsh.LoadMoreDelegate = new LoadMoreHelper (gridView, this);
            //Next, set the data object
            dsh.Data = gridItemsSorted.ToArray ();
            // Set the DataSource
            gridView.DataSource = dsh;
            // Turn off empty rows
            gridView.EmptyRows = false;
CLASSES:
    public class LoadMoreHelper : IGGridViewDataSourceHelperLoadMoreDelegate
            #region Members
            IGGridView gridView;
            RecentTestsTableViewController mRecentTestsTableViewController;
            #endregion
            #region Constructor
            public LoadMoreHelper (IGGridView GridView, RecentTestsTableViewController recentTestsTableViewController)
                gridView = GridView;
                mRecentTestsTableViewController = recentTestsTableViewController;
            #endregion
            #region Data Source Helper Methods
            public override IGGridViewLoadMoreCell ResolveLoadMoreCell (IGGridView gridView)
                IGGridViewLoadMoreCell cell = (IGGridViewLoadMoreCell)gridView.DequeueReusableCell ("LoadMore");
                return cell;
            public override bool NeedMoreRows (IGGridViewDataSourceHelper dataSource)
                return dataSource.Data.Length < mRecentTestsTableViewController.mTotalRecords;
            public override void LoadMoreRows (IGGridViewDataSourceHelper dataSource)
                mRecentTestsTableViewController.mPage++;
                if (mRecentTestsTableViewController.lstFunctionalTestGroupSummary.Count > 0)
                    mRecentTestsTableViewController.lstFunctionalTestGroupSummary.InsertRange (mRecentTestsTableViewController.lstFunctionalTestGroupSummary.Count - 1, LoadFunctionalTestGroup());
                //Rebind the datasource
                dataSource.Data = mRecentTestsTableViewController.lstFunctionalTestGroupSummary.ToArray ();
                //Update the display
                gridView.UpdateData ();
