65
Spline and SplineArea Series on same chart with Swift
I'm working on a test project with different charts and one chart I'm having issues with right now is a single chart with 2 spline area series and 1 spline series. I use Swift as my main language as well so I'm trying to keep this as a swift project and so far no matter how I try only one series shows up on the chart view (usually the last one added). I'm sure I'm missing something or don't have something configured correctly but didn't find anything in the documentation that helped. Here's the code that I've been working with
func setupArea1Series(time1 : Date, time2 : Date) {
        let dataSource = IGCategoryDateSeriesDataSourceHelper()
        dataSource.dates = [time1, time2]
        dataSource.values = [0, 1]
        let splineSeries = IGSplineAreaSeries(key: "series1")
        splineSeries.xAxis = self.dateAxis
        splineSeries.yAxis = self.valueAxis
        splineSeries.dataSource = dataSource
        self.chartView.addSeries(splineSeries)
    func setupSplineSeries(time3 : Date, time4 : Date, time5 : Date) {
        dataSource.dates = [time3, time4, time5]
        dataSource.values = [2, 3, 2]
        let splineSeries = IGSplineSeries(key: "series2")
    func setupSplineAreaSeries2(time6 : Date, time7 : Date) {
        dataSource.dates = [time6, time7]
        dataSource.values = [4, 0]
        let splineSeries = IGSplineAreaSeries(key: "series3")
func setupChartView() {
self.dateAxis = IGCategoryDateTimeXAxis(key: "xAxis")
        self.dateAxis.minimum = self.selectedDate.startOfDay
        self.dateAxis.maximum = self.selectedDate.endOfDay
        self.valueAxis = IGNumericYAxis(key: "yAxis")
        self.chartView = IGChartView(frame: CGRect(x: 0, y: 8, width: self.view.frame.size.width, height: self.view.frame.size.height-22))
        self.chartView.delegate = self
        self.chartView.add(self.dateAxis)
        self.chartView.add(self.valueAxis)
        self.chartView.isMultipleTouchEnabled = false
        self.sideMenuView.contentView.addSubview(chartView)
The chart setup is called in viewDidLoad and then the series are added with just random times during a given day for each series. If I change the order of the series it only creates the last one added.
  • 26458
    This appears to be a bug in the date time axis. I've submitted this issue in our tracking system.
    There are actually a few issues here. One is that series aren't respecting the date ranges you provided and another is the axis doesn't know how to handle series with different number of points.
