95
Crash on iPhone7 and iPhone7 Plus
We are getting crash reports from our iOS app. Crash reports come from only iPhone7 and iPhone7 Plus devices. We cant re-create crash at simulator. We have the infragistics version 2015.2 in our release version.
Crash point:
0x100746810 -[IGGridViewImageCell .cxx_destruct] (IGGridViewCell.m:1101)
This is sample log,
Incident Identifier: 25EBBF2F-67D1-49FE-AFA7-9015378C47D4
CrashReporter Key: 88ac68387af9ef39ded40a59e20c7ad336abddd8
Hardware Model: iPhone9,2
Process: xxxx [1367]
Path: /private/var/containers/Bundle/Application/28881C5D-1520-4B38-BCF5-7CE136DEE804/xxxx.app/xxxx
Identifier: com.xxxx.xxxx
Version: 4525 (3.0.6)
Code Type: ARM-64 (Native)
Role: Foreground
Parent Process: launchd [1]
Coalition: com.xxxx.xxxx [691]
Date/Time: 2016-09-19 07:54:07.7677 -0600
Launch Time: 2016-09-19 07:53:02.2270 -0600
OS Version: iPhone OS 10.0 (14A346)
Report Version: 104
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Triggered by Thread: 0
Last Exception Backtrace:
0 CoreFoundation 0x18b77c1c0 __exceptionPreprocess + 124 (NSException.m:165)
1 libobjc.A.dylib 0x18a1b455c objc_exception_throw + 56 (objc-exception.mm:521)
2 CoreFoundation 0x18b783278 -[NSObject(NSObject) doesNotRecognizeSelector:] + 140 (NSObject.m:328)
3 CoreFoundation 0x18b780278 ___forwarding___ + 916 (NSForwarding.m:3120)
4 CoreFoundation 0x18b67a59c _CF_forwarding_prep_0 + 92
5 UIKit 0x1915d2a94 -[UIImageView isAnimating] + 160 (UIImageView.m:1097)
6 UIKit 0x1915c2c30 -[UIImageView stopAnimating] + 136 (UIImageView.m:1087)
7 UIKit 0x1915c28f4 -[UIImageView dealloc] + 64 (UIImageView.m:619)
8 CoreFoundation 0x18b76be30 common_removeAllObjects + 188 (NSCollectionAux.h:71)
9 CoreFoundation 0x18b65dc70 -[__NSArrayM dealloc] + 28 (NSArray.m:974)
10 UIKit 0x1915c21b8 -[UIView dealloc] + 1284 (UIView.m:3501)
11 UIKit 0x1915c2b78 -[UIImageView dealloc] + 708 (UIImageView.m:631)
12 xxxx 0x10071a810 -[IGGridViewImageCell .cxx_destruct] + 76 (IGGridViewCell.m:1101)
13 libobjc.A.dylib 0x18a1b2f10 object_cxxDestructFromClass(objc_object*, objc_class*) + 148 (objc-class.mm:462)
14 libobjc.A.dylib 0x18a1bf6e0 objc_destructInstance + 92 (objc-runtime-new.mm:6483)
15 libobjc.A.dylib 0x18a1bf744 object_dispose + 28 (objc-runtime-new.mm:6502)
16 UIKit 0x1919621d0 -[UIResponder dealloc] + 156 (UIResponder.m:73)
17 UIKit 0x1915c2340 -[UIView dealloc] + 1676 (UIView.m:3537)
18 xxxx 0x10071ffdc -[CellInfo .cxx_destruct] + 88 (InternalStructures.m:437)
19 libobjc.A.dylib 0x18a1b2f10 object_cxxDestructFromClass(objc_object*, objc_class*) + 148 (objc-class.mm:462)
20 libobjc.A.dylib 0x18a1bf6e0 objc_destructInstance + 92 (objc-runtime-new.mm:6483)
21 libobjc.A.dylib 0x18a1bf744 object_dispose + 28 (objc-runtime-new.mm:6502)
22 CoreFoundation 0x18b76be30 common_removeAllObjects + 188 (NSCollectionAux.h:71)
23 CoreFoundation 0x18b65dc70 -[__NSArrayM dealloc] + 28 (NSArray.m:974)
24 xxxx 0x100720820 -[RowInfoBase .cxx_destruct] + 216 (InternalStructures.m:450)
25 libobjc.A.dylib 0x18a1b2f10 object_cxxDestructFromClass(objc_object*, objc_class*) + 148 (objc-class.mm:462)
26 libobjc.A.dylib 0x18a1bf6e0 objc_destructInstance + 92 (objc-runtime-new.mm:6483)
27 libobjc.A.dylib 0x18a1bf744 object_dispose + 28 (objc-runtime-new.mm:6502)
28 CoreFoundation 0x18b76be30 common_removeAllObjects + 188 (NSCollectionAux.h:71)
29 CoreFoundation 0x18b65dc70 -[__NSArrayM dealloc] + 28 (NSArray.m:974)
30 xxxx 0x1006f1d98 -[IGGridViewRenderer .cxx_destruct] + 996 (IGGridViewRenderer.m:25)
31 libobjc.A.dylib 0x18a1b2f10 object_cxxDestructFromClass(objc_object*, objc_class*) + 148 (objc-class.mm:462)
32 libobjc.A.dylib 0x18a1bf6e0 objc_destructInstance + 92 (objc-runtime-new.mm:6483)
33 libobjc.A.dylib 0x18a1bf744 object_dispose + 28 (objc-runtime-new.mm:6502)
34 xxxx 0x100713c48 -[IGGridView .cxx_destruct] + 640 (IGGridView.m:77)
35 libobjc.A.dylib 0x18a1b2f10 object_cxxDestructFromClass(objc_object*, objc_class*) + 148 (objc-class.mm:462)
36 libobjc.A.dylib 0x18a1bf6e0 objc_destructInstance + 92 (objc-runtime-new.mm:6483)
37 libobjc.A.dylib 0x18a1bf744 object_dispose + 28 (objc-runtime-new.mm:6502)
38 UIKit 0x1919621d0 -[UIResponder dealloc] + 156 (UIResponder.m:73)
39 UIKit 0x1915c2340 -[UIView dealloc] + 1676 (UIView.m:3537)
40 UIKit 0x1916a1128 -[UIScrollView dealloc] + 788 (UIScrollView.m:1023)
41 libobjc.A.dylib 0x18a1b2f10 object_cxxDestructFromClass(objc_object*, objc_class*) + 148 (objc-class.mm:462)
42 libobjc.A.dylib 0x18a1bf6e0 objc_destructInstance + 92 (objc-runtime-new.mm:6483)
43 libobjc.A.dylib 0x18a1bf744 object_dispose + 28 (objc-runtime-new.mm:6502)
44 UIKit 0x1919621d0 -[UIResponder dealloc] + 156 (UIResponder.m:73)
45 UIKit 0x191748f20 -[UIViewController dealloc] + 1784 (UIViewController.m:1905)
46 CoreFoundation 0x18b659d74 -[__NSArrayI dealloc] + 84 (NSCollectionAux.h:71)
47 UIKit 0x1918563a8 _runAfterCACommitDeferredBlocks + 616 (UIApplication.m:2462)
48 UIKit 0x191848018 _cleanUpAfterCAFlushAndRunDeferredBlocks + 560 (UIApplication.m:2428)
49 UIKit 0x1915b6d6c _afterCACommitHandler + 168 (UIApplication.m:2480)
50 CoreFoundation 0x18b7297dc __CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__ + 32 (CFRunLoop.c:1802)
51 CoreFoundation 0x18b72740c __CFRunLoopDoObservers + 372 (CFRunLoop.c:1898)
52 CoreFoundation 0x18b72789c __CFRunLoopRun + 1024 (CFRunLoop.c:2849)
53 CoreFoundation 0x18b656048 CFRunLoopRunSpecific + 444 (CFRunLoop.c:3113)
54 GraphicsServices 0x18d0d9198 GSEventRunModal + 180 (GSEvent.c:2245)
55 UIKit 0x19162f818 -[UIApplication _run] + 684 (UIApplication.m:2649)
56 UIKit 0x19162a550 UIApplicationMain + 208 (UIApplication.m:4091)
57 xxxx 0x100253080 main + 88 (main.m:14)
58 libdyld.dylib 0x18a6385b8 start + 4
Thread 0 name:
Thread 0 Crashed:
0 libsystem_kernel.dylib 0x000000018a74a014 __pthread_kill + 8
1 libsystem_pthread.dylib 0x000000018a811460 pthread_kill + 112 (pthread.c:1366)
2 libsystem_c.dylib 0x000000018a6be490 __abort + 144 (abort.c:128)
3 libsystem_c.dylib 0x000000018a6be400 abort + 152 (abort.c:99)
4 libc++abi.dylib 0x000000018a1892d4 abort_message + 132 (abort_message.cpp:78)
5 libc++abi.dylib 0x000000018a1a6cc0 default_terminate_handler() + 304 (cxa_default_handlers.cpp:68)
6 libobjc.A.dylib 0x000000018a1b4844 _objc_terminate() + 124 (objc-exception.mm:657)
7 xxxx 0x00000001007ae6c0 CLSTerminateHandler() + 280
8 libc++abi.dylib 0x000000018a1a366c std::__terminate(void (*)()) + 16 (cxa_handlers.cpp:68)
9 libc++abi.dylib 0x000000018a1a3234 __cxa_rethrow + 144 (cxa_exception.cpp:584)
10 libobjc.A.dylib 0x000000018a1b471c objc_exception_rethrow + 44 (objc-exception.mm:560)
11 CoreFoundation 0x000000018b6560bc CFRunLoopRunSpecific + 560 (CFRunLoop.c:3126)
12 GraphicsServices 0x000000018d0d9198 GSEventRunModal + 180 (GSEvent.c:2245)
13 UIKit 0x000000019162f818 -[UIApplication _run] + 684 (UIApplication.m:2649)
14 UIKit 0x000000019162a550 UIApplicationMain + 208 (UIApplication.m:4091)
15 xxxx 0x0000000100253080 main + 88 (main.m:14)
16 libdyld.dylib 0x000000018a6385b8 start + 4
Thread 1 name:
Thread 1:
0 libsystem_kernel.dylib 0x000000018a72c16c mach_msg_trap + 8
1 libsystem_kernel.dylib 0x000000018a72bfdc mach_msg + 72 (mach_msg.c:103)
2 CoreFoundation 0x000000018b729cec __CFRunLoopServiceMachPort + 192 (CFRunLoop.c:2527)
3 CoreFoundation 0x000000018b727908 __CFRunLoopRun + 1132 (CFRunLoop.c:2870)
4 CoreFoundation 0x000000018b656048 CFRunLoopRunSpecific + 444 (CFRunLoop.c:3113)
5 Foundation 0x000000018c164b1c -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 304 (NSRunLoop.m:367)
6 Foundation 0x000000018c18560c -[NSRunLoop(NSRunLoop) runUntilDate:] + 96 (NSRunLoop.m:411)
7 UIKit 0x0000000191fa4e6c -[UIEventFetcher threadMain] + 136 (UIEventFetcher.m:279)
8 Foundation 0x000000018c26250c __NSThread__start__ + 1024 (NSThread.m:1163)
9 libsystem_pthread.dylib 0x000000018a80f860 _pthread_body + 240 (pthread.c:697)
10 libsystem_pthread.dylib 0x000000018a80f770 _pthread_start + 284 (pthread.c:744)
11 libsystem_pthread.dylib 0x000000018a80cdbc thread_start + 4
Thread 2 name:
Thread 2:
5 CFNetwork 0x000000018be43cec +[NSURLConnection(Loader) _resourceLoadLoop:] + 336 (NSURLConnection.mm:364)
6 Foundation 0x000000018c26250c __NSThread__start__ + 1024 (NSThread.m:1163)
7 libsystem_pthread.dylib 0x000000018a80f860 _pthread_body + 240 (pthread.c:697)
8 libsystem_pthread.dylib 0x000000018a80f770 _pthread_start + 284 (pthread.c:744)
9 libsystem_pthread.dylib 0x000000018a80cdbc thread_start + 4
Thread 3 name:
Thread 3:
2 xxxx 0x000000010079cef0 CLSMachExceptionServer + 100
3 libsystem_pthread.dylib 0x000000018a80f860 _pthread_body + 240 (pthread.c:697)
4 libsystem_pthread.dylib 0x000000018a80f770 _pthread_start + 284 (pthread.c:744)
5 libsystem_pthread.dylib 0x000000018a80cdbc thread_start + 4
Thread 4 name:
Thread 4:
5 AVFAudio 0x00000001a4cd2fe8 GenericRunLoopThread::Entry(void*) + 164 (GenericRunLoopThread.h:106)
6 AVFAudio 0x00000001a4cf8f14 CAPThread::Entry(CAPThread*) + 84
Thread 5 name:
Thread 5:
5 CoreFoundation 0x000000018b6a38d4 CFRunLoopRun + 112 (CFRunLoop.c:3136)
6 CoreMotion 0x000000019249d7dc CLMotionCore::runMotionThread(void*) + 824 (CLMotionCore.mm:262)
Thread 6:
0 libsystem_kernel.dylib 0x000000018a749e1c __psynch_cvwait + 8
1 libsystem_pthread.dylib 0x000000018a80e9d0 _pthread_cond_wait + 640 (pthread_cond.c:536)
2 libc++.1.dylib 0x000000018a1393ec std::__1::condition_variable::wait(std::__1::unique_lock<std::__1::mutex>&) + 56 (condition_variable.cpp:44)
3 JavaScriptCore 0x000000018fefe548 void std::__1::condition_variable_any::wait<std::__1::unique_lock<bmalloc::Mutex> >(std::__1::unique_lock<bmalloc::Mutex>&) + 112 (condition_variable:202)
4 JavaScriptCore 0x000000018fefe4bc bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>::threadRunLoop() + 168 (condition_variable:211)
5 JavaScriptCore 0x000000018fefe39c bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>::threadEntryPoint(bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>*) + 12 (AsyncTask.h:106)
6 JavaScriptCore 0x000000018fefe64c void* std::__1::__thread_proxy<std::__1::tuple<void (*)(bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>*), bmalloc::AsyncTask<bmalloc::Heap, void (bmalloc::Heap::*)()>*> >(void*) + 92 (__functional_base:416)
Thread 7:
0 libsystem_kernel.dylib 0x000000018a74aa88 __workq_kernreturn + 8
1 libsystem_pthread.dylib 0x000000018a80d36c _pthread_wqthread + 1452 (pthread.c:2205)
2 libsystem_pthread.dylib 0x000000018a80cdb4 start_wqthread + 4
Thread 8:
Thread 9:
0 libsystem_pthread.dylib 0x000000018a80cdb0 start_wqthread + 0
Thread 10:
Thread 11:
Thread 12:
Thread 13:
