is there a way to control type of the border line (say dashed etc...) and corner radius in "edit mode" rectangle?
Thank you
Mark
Steve,
Worked as suggested ;~)
that is great, thank you
will let you know how it goes
Hey Mark,
Currently the only thing you can really change about the editItem border is the color.
I did add a new delegate method that may help you though. It's called:
in Objc:
-(void)flowLayoutView:(IGFlowLayoutView*)flowLayoutView editViewFrameChanged:(CGRect)frame;
in C#:
public void FlowLayoutViewEditViewFrameChanged(IGFlowLayoutView flowLayout, Rectf frame);
Basically, you could set the existing border color to transparent, and then display your own view, and update its frame via this method.
Just as a warning though, i haven't actually tested this out, it just theoretically should work.
Hope this helps,
-SteveZ
