I have a UIViewController which shows apples MKMapView.
It has a tap handler on it, which when I long press on the map, it calls ...
-(void)windowTapped:(UIGestureRecognizer*)recognizer
...in my UIViewController.
I'm trying to restructure this UIViewController so that it uses the IGSideMenuView behind the map control, but whatever I've tried, I no longer receive the tap gesture in my UIViewController.
Please see my attached code sample.
In -(void)addMapViewToSelf, my tap handler works perfectly.
In -(void)addMapViewToSideMenuView, the tap handler ceases to work, and I've tried all of these lines, and none makes it work...
[appleMapView addGestureRecognizer:tapRecognizer]
[theSideMenuView addGestureRecognizer:tapRecognizer]
[theSideMenuView.contentView addGestureRecognizer:tapRecognizer]
[self.view addGestureRecognizer:tapRecognizer]
Hi David,
I've attached a sample that uses the MKMapView in the contentView of the IGSideMenuView. The side menu is shown/closed when the user taps the hamburger button in the navigation bar. This scenario works best when using a MKMapView that will cover the entire contentView, as the map handles several complex gestures and we don't want to create any strange behavior for the user.
