630
Custom Markers for StackedColumnSeries
i have a stackedColumnSeries chart with for e.g. 3 series. I used the ResolveMarkerView Delegate for custom markers. On every call of the ResolveMarkerView ithe Parameter item contains all the whole series-data (RowValue1-RowValue3) for one column of the chart. Parameter index is always 0. How can i determine which RowValue (Series) has to be used for current call of ResolverMarkerView.
Thanks Johann
  • 26458
    Verified Answer
    Hi Johann,
    You should be able to tell which fragment of the stack is asking for the marker if you look at the 'options' parameter.
    options.StackedFragment.ValueProperty will be the string name of the property that binds your data. Dealing with the stacked series is a bit tricky, because the entire stacked series(all fragments) is treated as a single series. The index refers to the index of the whole stack of columns with respect to where it is on the axis. Since each stack contains multiple columns and the item parameter contains data from all the values in the stack, it is not obvious which fragment you're dealing with. That's why we added the options parameter, so we can provide as much useful information as possible.
    For example, to get the current value in ResolveMarkerView you can do this:
    double value = item[options.StackedFragment.ValueProperty]
