235
2015 Vol 2 - Avalanche of Warning when compiling under Xcode 7.1 (7B91b)
Latest version of Xcode (7.1) updated today. (btw same issue with previous version of Xcode)
iOS deployment target: 7.1 (required for specific installed user base)
Have downloaded and installed latest version of NUCLiOS: 2015 Vol 2
Important to note that this app has been using NUCLiOS since the 2012 version: This is "dust off the app for some changes" and to refactor for iOS 9.
While attempting to build against "Generic iOS Device" The compiler is generating an avalanche of warnings. (Stopped listing them past 200).
(I'm hoping this is just a "oh, just set this intuitively obvious flag" issue... And since it has so many references to IG.framework...)
Thanks!
while processing /Applications/Xcode.app/Contents/Developer/Library/Frameworks/IG.framework/IG(IGGridViewSingleFieldDynamicColumnDataSourceHelper.o):
warning: /var/folders/43/dmtr18tj19jcwfk5h4jkd8240000gn/C/org.llvm.clang.jasonberes/ModuleCache/1W1M0MFNPGILX/Foundation-A3SOD99KJ0S9.pcm: No such file or directory
warning: /var/folders/43/dmtr18tj19jcwfk5h4jkd8240000gn/C/org.llvm.clang.jasonberes/ModuleCache/1W1M0MFNPGILX/Foundation-A3SOD99KJ0S9.pcm: No object file for requested architecture
warning: /var/folders/43/dmtr18tj19jcwfk5h4jkd8240000gn/C/org.llvm.clang.jasonberes/ModuleCache/1W1M0MFNPGILX/CoreGraphics-1YQ59ILDR3NYI.pcm: No such file or directory
warning: /var/folders/43/dmtr18tj19jcwfk5h4jkd8240000gn/C/org.llvm.clang.jasonberes/ModuleCache/1W1M0MFNPGILX/CoreGraphics-1YQ59ILDR3NYI.pcm: No object file for requested architecture
warning: /var/folders/43/dmtr18tj19jcwfk5h4jkd8240000gn/C/org.llvm.clang.jasonberes/ModuleCache/1W1M0MFNPGILX/UIKit-2LM3EQU7VVY4O.pcm: No such file or directory
warning: /var/folders/43/dmtr18tj19jcwfk5h4jkd8240000gn/C/org.llvm.clang.jasonberes/ModuleCache/1W1M0MFNPGILX/UIKit-2LM3EQU7VVY4O.pcm: No object file for requested architecture
warning: /var/folders/43/dmtr18tj19jcwfk5h4jkd8240000gn/C/org.llvm.clang.jasonberes/ModuleCache/1W1M0MFNPGILX/QuartzCore-3I7S0M4UEAD0U.pcm: No such file or directory
warning: /var/folders/43/dmtr18tj19jcwfk5h4jkd8240000gn/C/org.llvm.clang.jasonberes/ModuleCache/1W1M0MFNPGILX/QuartzCore-3I7S0M4UEAD0U.pcm: No object file for requested architecture
warning: /var/folders/43/dmtr18tj19jcwfk5h4jkd8240000gn/C/org.llvm.clang.jasonberes/ModuleCache/1W1M0MFNPGILX/ObjectiveC-2CD0WTQVXITO7.pcm: No such file or directory
warning: /var/folders/43/dmtr18tj19jcwfk5h4jkd8240000gn/C/org.llvm.clang.jasonberes/ModuleCache/1W1M0MFNPGILX/ObjectiveC-2CD0WTQVXITO7.pcm: No object file for requested architecture
warning: Could not resolve external type c:objc(cs)NSObject
warning: Could not resolve external type c:objc(cs)NSArray
warning: Could not resolve external type c:objc(cs)NSString
