I addeda graphic as subview of a view with blue backgroundcolor , I can not set the background color of the chart in white. how can I do to remove the " transparency " ?
I tried this code but does not work
IGChartThemeDefinition *theme = [IGChartGradientThemes IGTheme]; theme.backgroundColor = [UIColor whiteColor]; theme.plotAreaPalette.color = [[IGBrush alloc] initWithColor:[UIColor whiteColor]];
chart.theme = theme;
Here a preview
thanks Max
It looks like the background property isn't working for some reason. We'll investigate this further and fix it as soon as possible. I've entered a bug report in our system for you.Until this gets fixed the best workaround is to either change the parent view's background to white, or, if that isn't possible, add another view with white background to host the chart.
Sorry for the inconvenience.
