135
CSS Styles
I set all the css class properties (CssClass, SelectedCssClass, etc) for the WebExplorerBar, ExplorerBarGroup and ExplorerBarItem objects in the codebehind.
Yet, the rendered html is inserting its own css class names into the rendered content. For example, <a class="igeb_ItemLink" .../>.
I think this is causing my formatting problems since it's not respecting the styles I set.
I'm using NetAdvantage 2013.1.
Any help is appreciated.
Thanks.
  • 9190
    Verified Answer
    Thank you for posting on our forums.
    I am unable to reproduce this issue using build 13.1.20131.2331 for Infragistics ASP.NET 2013 Volume 1.  I have attached the sample project I used to test this.  Please test this project on your PC; whether or not it works correctly may help indicate the nature of this problem.
    If the project does show the product feature working correctly, this indicates a possible problem in the code of your application.  It will help if you can provide a small, isolated sample application that demonstrates the behavior you are seeing.
    Or, if this sample project is not an accurate demonstration of what you're trying to do, please feel free to modify it and send it back, or send a small sample project of your own if you have one.
    Please let me know if you have any questions regarding this matter.
    WebExplorerBarStylingCB145585.zip
