155
WHDG - Commiting childgrid batch-updates
Hello, I'm having a big problem here. I'm using a WHDG with a WebHierarchicalDataSource connected to 2 SQLDataSources for editing a master-Detail view.
This is how my grid is defined:
<ig:WebHierarchicalDataGrid ID="WebHierarchicalDataGrid1" ClientIDMode="Static" Width="100%" runat="server" AutoGenerateColumns="False" ValidateRequestMode="Disabled" AutoGenerateBands="False" DataKeyFields="ID" DataMember="SqlDataSource1_DefaultView" DataSourceID="WebHierarchicalDataSource1" Key="SqlDataSource1_DefaultView" OnRowUpdating="WebDataGrid1_RowUpdating" >
<Bands>
<ig:Band AutoGenerateColumns="False" DataMember="SqlDataSource2_DefaultView" Key="SqlDataSource2_DefaultView" DataKeyFields="ID, CHILD_ID" OnRowUpdating="WebDataGrid1_RowUpdating">
<Columns>
<ig:BoundDataField DataFieldName="ID" Key="ID" Hidden="true">
<Header Text="ID">Header>
ig:BoundDataField>
             <ig:BoundDataField DataFieldName="CHILD_ID" Key="CHILD_ID">
<Header Text="CHILD_ID">Header>
ig:BoundDataField>
        Columns>
ig:Band>
Bands>
<Columns>
<Header Text="ID">
Header>
ig:BoundDataField>
<ig:BoundDataField DataFieldName="DESCRIPTION" Key="DESCRIPTION">
<Header Text="DESCRIPTION">
Header>
ig:BoundDataField>
Columns>
<Behaviors>
<ig:EditingCore AutoCRUD="False" BatchUpdating="True" EnableInheritance="true">
<Behaviors>
<ig:RowEditing EnableInheritance="true">
ig:RowEditing >
<ig:RowDeleting EnableInheritance="true">
ig:RowDeleting>
<ig:RowAdding EnableInheritance="true">
ig:RowAdding>
Behaviors>
ig:EditingCore>
Behaviors>
ig:WebHierarchicalDataGrid>
Then I'm calling the following JavaScript function when clicking on a Save-Button:
function commitWHDGrid() {
     var editingCore = $find("WebHierarchicalDataGrid1").get_gridView().get_behaviors().get_editingCore();
          NProgress.start();
     $find("WebHierarchicalDataGrid1").get_gridView().get_behaviors().get_editingCore().commit();
     return false;
When I edit a row in the Master-View (the main grid), and then click the button, my RowUpdating method is being called. When I on the other Hand, update one of the child grid rows and press the button, the onRowUpdating Event is not being called.
What am I doing wrong?
For the sake of completeness:
protected void WebDataGrid1_RowUpdating(object sender, Infragistics.Web.UI.GridControls.RowUpdatingEventArgs e)
     ContainerGrid grid = ((ContainerGrid)sender);
     if (grid.Level == 0)
                 // update in main grid occured
             SqlDataSource1.UpdateParameters["ID"].DefaultValue = e.OldValues["ID"].ToString();
     }else{
        // update in child grid occured
             SqlDataSource2.UpdateParameters["ID"].DefaultValue = e.OldValues["ID"].ToString();
     WebHierarchicalDataGrid1.Rows.Clear();
     WebHierarchicalDataGrid1.DataBind();
     WebHierarchicalDataGrid1.GridView.RequestFullAsyncRender();
