205
Error in migration from 2011 to 2014 vol 2 suite
I'm porting all the site from the old dll to the new. For example from UltraWebGrid to WebDataGrid and so on.
The problem arise when I Add the new dll: from Infragistics4.WebUI.UltraWebChart.v11.1.dll to Infragistics4.WebUI.UltraWebChart.v14.2
The problem is that, then it ask me also to import and substitute Infragistics4.WebUI.Shared.v11.1.dll with the new Infragistics4.WebUI.Shared.v14.2
In the web config a register the Chart in this way:
<!--<add tagPrefix="igchart" namespace="Infragistics.WebUI.UltraWebChart" assembly="Infragistics4.WebUI.UltraWebChart.v11.1, Version=11.1.20111.2238, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"/>-->
<add tagPrefix="igchart" namespace="Infragistics.WebUI.UltraWebChart" assembly="Infragistics4.WebUI.UltraWebChart.v14.2, Version=14.2.20142.2480, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"/>
Now I have an unfinished list of error of this kind:
Error 107 The type 'Infragistics.WebUI.Shared.IProvideDefaultStyles' is defined in an assembly that is not referenced. You must add a reference to assembly 'Infragistics4.WebUI.Shared.v11.1, Version=11.1.20111.2238, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb'. C:\Dev\ORSS_Infragistic\ORSS New INFRAGISTIC\orssweb\Indicatore\frm_MSB_IWB.aspx.cs 180 17 ORMWeb
I And I don't know how to fix.
Maybe the new functionality are moved into another dll that I have to import?
I'm porting all the site from the old dll to the new. For example from UltraWebGrid to WebDataGrid and so on. The problem is that when I Add the new dll: from Infragistics4.WebUI.UltraWebChart.v11.1.dll to Infragistics4.WebUI.UltraWebChart.v14.2
The problem is that then it ask me also to import and substitute Infragistics4.WebUI.Shared.v11.1.dll with the new Infragistics4.WebUI.Shared.v14.2
I don't know because a lot of error arise and I don't know how to fix.
Maybe the new funcitonality are moved into another dll that I have to import?
  • 16310
    Thank you for posting in the Infragistics community !
    This type of error message makes me think that while upgrading you have missed to remove somewhere in your project a reference to a 11.1 version assembly. My very first suggestions is to make sure you have removed all old references by checking at all places where it is possible to have left overs:
    - web.config
    - register directives in .aspx pages
    - licenses.licx file - you can clear all the contenf from this file
    - double click over the website > Properties pages > References (it is not valid for projects but for websites only)
    Also, I am not sure that you really need those <add tagPrefix...? in web.config. It should be enough to have those add directives in web.config:
          <assemblies>
            <add assembly="Infragistics4.WebUI.UltraWebChart.v14.2, Version=14.2.20142.2317, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
            <add assembly="Infragistics4.WebUI.Shared.v14.2, Version=14.2.20142.2317, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB"/>
          </assemblies>
    along with the register directives in the .aspx:
    <%@ Register Assembly="Infragistics4.Web.v14.2, Version=14.2.20142.2317, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
        Namespace="Infragistics.Web.UI" TagPrefix="ig" %>
    Please try the above suggestions and let me know if it helped, or if you need any further assistance on the matter.
