225
Updated SummaryRow
I have a summaryRow defined by on a column who is readonly.
I used Events ExitEditMode in CellEditing properties in order to update this one.
e.g :
Column A (is editable) = Q (quantity)
Column B (is editable) = P (price)
Column C (not editable) = Q * P (updated with javascript function)
When, the Column C is updated, i would like to update summaryrow too...
Ps : is there a way in javascript to raise a cell updated event or a another way ??
Salvatore
  • 20255
    Verified Answer
    Thank you for your question.
    I have created a sample for you in order to show you how to implement similar scenario, basically the read-only cell will be changed and then the summary row will be updated according that change. Please have a look at the sample and let me know if I am missing something from your scenario.
    Code snippet:
    <script type="text/javascript">
        function WebDataGrid_CellEditing_ExitingEditMode(sender, eventArgs) {
            var columnKey = eventArgs.getCell().get_column().get_key();
            switch (columnKey) {
                case "Salary":
                    eventArgs.getCell().get_row().get_cellByColumnKey("Total").set_value(eventArgs.getCell().get_value() +
                        eventArgs.getCell().get_row().get_cellByColumnKey("Bonuses").get_value());
                    break;
                case "Bonuses":
                        eventArgs.getCell().get_row().get_cellByColumnKey("Salary").get_value());
                    break;
                default:
        function WebDataGrid_SummaryRow_Initialize(sender, eventArgs) {
            var e = eventArgs;
        function WebDataGrid_Initialize(sender, eventArgs) {
            var row;
            var cellTotal;
            for (var i = 0; i < sender.get_rows().get_length() ; i++) {
                row = sender.get_rows().get_row(i);
                cellTotal = row.get_cellByColumnKey("Total");
                cellTotal.set_value(row.get_cellByColumnKey("Salary").get_value() + row.get_cellByColumnKey("Bonuses").get_value());
        </script>
    SummaryRowExampleWithReadOnlyColumn.zip
