1620
WebTab: Upgrading "UltraWebTab" to "WebTab"......properties not found....plzzz help ASAP...........
I am converting Infragistics 2010 v2 CLR3.5 to Infragistics 2014 v2 using 4.5 CLR using Visual Studio 2013 Professional Update 4. I am getting following error while building the project. Please reply immediately..........
Below is the code of "UltraWebTab", I would like to know the new properties of "WebTab" which I was unable to found....Plzz reply POINT-WISE ...after my points which would be easier for me to implement.
  1. Scroll Buttons: I am not able to see <PressedStyle BackColor="#E1EDFF"> and <HoverStyle BackColor="LightSteelBlue"> ... please let me know alternative so that my functionality don't get disturbed.
  2. ClientEvents: What is the same alternative property of "BeforeSelectedTabChange" as this one this one is not valid attribute coming while upgrading  <ClientEvents  BeforeSelectedTabChange="contentTab_BeforeSelectedTabChange"></ClientEvents>
  3. Under "Tabs" - Tab Key=1 : Under <Tabs>, <igtab:Tab Key="1"> it is not taking "Tab", what should I use?? *********This is really very important as I am using total 5 different Tabs like Tab Key=2, Tab Key=3, Tab Key=4, Tab Key=5..............like how this is one Tab Key=1 shown in below code such different Tab key till 5 being used so code is too long. Below is just one example I pasted here for your reference......
  4. ContentTemplate: <ContentTemplate> element ContentTemplate is not supported is coming but it is a huge functionality so give the alternative of this.
<igtab:UltraWebTab ID="contentTab" runat="server" Height="100%" Width="100%" DisplayMode="Scrollable">
                                    <ScrollButtons>
                                        </PressedStyle>
                                        </HoverStyle>
                                        <Style Height="18px" Font-Size="8pt" Font-Names="Verdana">
                                        </Style>
                                    </ScrollButtons>
                                    <ClientSideEvents BeforeSelectedTabChange="contentTab_BeforeSelectedTabChange"></ClientSideEvents>
                                    <DefaultTabStyle Height="26px" Font-Size="8pt" Font-Names="Verdana" BackColor="#E1EDFF">
                                    </DefaultTabStyle>
                                    <RoundedImage SelectedImage="./images/ig_tab_blueb2.gif" NormalImage="./images/ig_tab_blueb1.gif"
                                        FillStyle="LeftMergedWithCenter"></RoundedImage>
                                    <DefaultTabSeparatorStyle Font-Size="8pt" Font-Names="Verdana">
                                    </DefaultTabSeparatorStyle>
                                    <Tabs>
                                        <igtab:Tab Key="1">
                                            <ContentTemplate>
                                                <table id="grid1Table" cellspacing="0" cellpadding="0" width="100%" border="0">
                                                    <tr>
                                                        <td id="grid1Td1" style="font-weightboldfont-size10ptcolorwhitefont-familyVerdana;                                                             background-imageurl(./images/taskBkgd.gif)" nowrap="nowrap" width="90%" height="25"
                                                            runat="server">
                                                        </td>
                                                        <td style="background-imageurl(./images/taskBkgd.gif)" height="25">
                                                        </td>
                                                        <td nowrap="nowrap" align="right" style="background-imageurl(./images/taskBkgd.gif)"
                                                            height="25">
                                                            <a id="lnkBulkExport1" style="font-weightboldfont-size8ptcolorwhitefont-familyVerdana"
        href="#" runat="server">Export All</a> &#160;&#160; <a id="lnkFR1" style="font-weightbold;        font-size8ptcolorwhitefont-familyVerdana" href="#" runat="server">Bulk
        Replace</a>&#160;
                                                            <asp:Image ID="imgGridCopy1" Style="cursorhand" runat="server" ToolTip="Copy to Clipboard - F12"
        ImageUrl=".\images\copy.ico"></asp:Image>&#160;
                                                            <asp:Image ID="imgGridhlp1" Style="cursorhand" runat="server" ToolTip="Launch Help File (If Available)"
        ImageUrl=".\images\help.gif"></asp:Image>
                                                        </td>
                                                    </tr>
                                                    <tr>
                                                        <td colspan="2">
                                                            <asp:Label ID="lblErr1" runat="server"></asp:Label>
                                                        </td>
                                                    </tr>
                                                    <tr>
                                                        <td colspan="3">
                                                            <igtxt:WebDateTimeEdit ID="WebDateTimeEdit1" runat="server" Visible="False" DisplayModeFormat="MM/dd/yyyy hh:mm:ss tt"
        EditModeFormat="MM/dd/yyyy hh:mm:ss tt">
                                                            </igtxt:WebDateTimeEdit>
                                                            <igtxt:WebDateTimeEdit ID="WebDateTimeEdit_DateOnly1" runat="server" Visible="False"
        DisplayModeFormat="MM/dd/yyyy" EditModeFormat="MM/dd/yyyy">
                                                            <igtxt:WebTextEdit ID="WebTextEdit1" runat="server" Visible="False">
                                                            </igtxt:WebTextEdit>
                                                            <igtxt:WebNumericEdit ID="WebNumericEdit1" runat="server" Visible="False">
                                                            </igtxt:WebNumericEdit>
                                                            <igtbl:UltraWebGrid ID="grid_1" runat="server" Height="200px" Width="325px">
        <DisplayLayout Name="gridx1" BorderCollapseDefault="Separate" RowHeightDefault="20px"
        Version="4.00">
        <FrameStyle BorderStyle="Solid" BorderWidth="1px" Font-Names="Verdana" Font-Size="8pt"
        </FrameStyle>
        <Pager>
        <PagerStyle BackColor="LightGray" BorderStyle="Solid" BorderWidth="1px">
        <BorderDetails ColorLeft="White" ColorTop="White" />
        </PagerStyle>
        </Pager>
        <EditCellStyleDefault BorderStyle="None" BorderWidth="0px">
        </EditCellStyleDefault>
        <HeaderStyleDefault BackColor="LightGray" BorderStyle="Solid">
        </HeaderStyleDefault>
        <RowStyleDefault BackColor="White" BorderColor="Gray" BorderStyle="Solid" BorderWidth="1px"
        Font-Names="Verdana" Font-Size="8pt">
        <Padding Left="3px" />
        </RowStyleDefault>
        <AddNewBox>
        <BoxStyle BackColor="LightGray" BorderStyle="Solid" BorderWidth="1px">
        </BoxStyle>
        </AddNewBox>
        <ActivationObject BorderColor="" BorderWidth="">
        </ActivationObject>
        </DisplayLayout>
        <Bands>
        <igtbl:UltraGridBand>
        <AddNewRow View="NotSet" Visible="NotSet">
        </AddNewRow>
        </igtbl:UltraGridBand>
        </Bands>
                                                            </igtbl:UltraWebGrid>
                                                        </td>
                                                    </tr>
                                                    <tr>
                                                        <td align="center" colspan="3">
                                                            <input id="btnAdd1" type="button" value=" Add  " runat="server" />
                                                            <input id="btnDelete1" type="hidden" value="Delete" runat="server" />
                                                            <asp:Button ID="btnClearAllMessages1" runat="server" Text="Bulk Message Update">
                                                            </asp:Button>
                                                        </td>
                                                    </tr>
                                                </table>
                                            </ContentTemplate>
                                        </igtab:Tab>
