165
Datepicker Calender aligment issue
Hi Team,
Earlier i have used WebDateChooser control. Now migrating to WebDatepicker. Can you please provide Equivalent below code in webDatepicker.
'Align the Calendar dropdown to be centered under the DateChooser.
dateChooser.DropDownAlignment = Infragistics.WebUI.WebDropDown.DropDownAlignment.Center
'We can apply a StylePreset to the Calendar, instead of manually setting 'these properties.
dateChooser.CalendarLayout.Calendar.SetStylePresets(Infragistics.WebUI.WebSchedule.CalendarStylePreset.Silver, _
Infragistics.WebUI.WebSchedule.CalendarPresetNextPrevFormat.SmallTriangle, True)
Krishna | 9000701514
  • 16310
    It seems that such control over the calendar positioning is not available out of the box. I have tried to customize it during client side events but it still does not seem consistent and reliable resolution. Considering the above I suggest that you simply set the same width to both the WebDatePicker and the WebMonthCalendar. Please let me know if this would work for you, otherwise I will further try to find alternative solution.
            <ig:WebDatePicker ID="WebDatePicker1" runat="server" DropDownCalendarID="WebMonthCalendar1"
                Height="35px" Width="200px">
            </ig:WebDatePicker>
            <ig:WebMonthCalendar ID="WebMonthCalendar1" runat="server" Height="198px" Width="200px">
            </ig:WebMonthCalendar>
