How can i bind WebDataGrid inside of WebDropDown?
I'm using c# and "Infragistics 14.2 CLR 4.5.1".
When i bind WebDataGrid it works fine but when i try to bind the webdatagrid inside the webdropdown, its not showing the values(data table) while running. I don't know what i missed in the code.
I think this should be simple to achieve but I can't see how?
Please help me with a solution for this issue. I had attached my sample code and screenshots for your reference.
Give me sample if possible.
Anees
Thank you for contacting Infragistics’ support.
I have investigated the case. The seeking functionality can be accomplished by creating a multi-column WebDropDown using Templates. The WebDropDown Template feature allows the use of different controls inside the drop-down container. I’m attaching a sample as well as a screenshot.
Please, let me know how my suggestion work for you.
