I have a WHDG that does work properly, except to update cell on the enter key instead a row selection change, but that is another post. I have enabled the delete row and the outline of the delete button will display on hover without the image when not in compatibility view. Well that is fine, I just have to make everyone set the compatibility view. I guess. But when in compatibility view, when the delete buttons shows fine with the hover a date picker editor that I have on the grid doesn't open properly when the cell is active. I set the width and everything but the text box part of the datepickereditor is simply at a 2px width no matter what I do.(When in compatibility view) If I take the site out of compatibility view the datepickereditor works fine but the delete button hover only shows the outline. Of course, I need both controls to display properly in IE11 regardless of the compatibility view settings. How do I do that? I am using Version 14.1.20141.1015, IIS is the Visual Studio 2012 right now, IE11. I have tried the Edge settings and the other version setting with F12 but still the same problem. When one control works the other does not.
Yes. I decided to do that. I just liked the look of the button in the grid class. Funny. I didn't know it was an X. Ha. Thank you.
Hello Nbizub,
The X delete button is achieved by using pseudo elements, which are supported by IE8+. I believe that when in Compatibility mode IE ignore this elements and you only see the outline of the button. A much simpler solution would be just to add a different background image on this element that looks like X. You can open ig_dataGrid.css file and find the .igg_RowDeletingButton class. You can add a background-image property and you are all set up.
Please let me know if you need any assistance on how to implement this.
