Hi
I migrate a project using a UltraGrid to WebHierachicalDataGrid.
I calculate the sum and put it on a summary on the left side, because the colums used for the calculation is hidden.
For the UltraGrid i use the following script
Dim SHESummary as Infragistics.Win.UltraWinGrid.SummarySettings;
TypeMSummary= ultraGrid1.DisplayLayout.Bands[0].Summaries.Add("type_M", Infragistics.Win.UltraWinGrid.SummaryType.Sum, ultraGrid1.DisplayLayout.Bands(0).Columns("type_M"), Infragistics.Win.UltraWinGrid.SummaryPosition.Left);
TypeMSummary.DisplayFormat= "Total = {0}";
Now when using WebHierachicalDataGrid, i try to do the same, but with no success.
Here is the script i use on the initialiedBand Event.
e.Band.Behaviors.CreateBehavior<SummaryRow>();
e.Band.Behaviors.SummaryRow.Enabled =true;
ColumnSummaryInfo unitAmelioration = new ColumnSummaryInfo();
unitAmelioration.ColumnKey ="Nom_Group";
e.Band.Behaviors.SummaryRow.ColumnSummaries.Add(unitAmelioration);
WebHierarchicalDataGrid1.RefreshBehaviors();
It is possible to do the same and How?
Thank's
Christophe
Let me know if I may be of further assistance.
Thank you for using our forum.
Currently we do not have such functionality, to add a position for the summary, although I can suggest you to use CSS approach in order to change the position for each summary.
Each SummarySetting have CssClass which can be used to apply some style to the Summary.
