I am having trouble getting my project to accept the WebDialogWindow. I have used this before and cant determine what is causing the problem.
I added the following to my .aspx page which has a Master Page and causes the error WebDialogWindow is ambiguous in the namespace 'Infragistics.Web.UI.LayoutControls'.
<%@ Page Title="" Language="VB" MasterPageFile="~/MasterPage.master" AutoEventWireup="true" CodeFile="ContractDescriptionList.aspx.vb" Inherits="ContractDescriptionList" %>
<%@ Register Assembly="Infragistics4.Web.v13.1, Version=13.1.20131.2045, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
Namespace="Infragistics.Web.UI.LayoutControls" TagPrefix="ig" %>
Output error = C:\projects\Lease\ContractDescriptionList.aspx.vb(30,0): error BC30560: 'DialogWindowState' is ambiguous in the namespace 'Infragistics.Web.UI.LayoutControls'.
Hi Mike, I had to rebuild the project due to multiple versions of infragistics causing the ambiguity issue. My new project is ok now. Thanks.
Hello Jon,
I have created a sample WebDialogWindow where I change the window state. I have been unable to reproduce the behavior you describe. I used build v13.1.20131.2045. Please run my sample and let me know what behavior you see. Can you please provide me with an isolated sample that reproduces this issue?
Note I have deleted the ig_res folder for file size to be attached to the forum thread.
Please let me know if you have any questions concerning this matter.
