90
WebNumericEditor value does not have correct decimal numbers
I am using the WebNumericEditor on a form to add/edit some data. My problem is the editing part. If i create a new entry with "2.3" as value, it's stored correctly within the database. If i want to edit this entry, the form shows the value "2.0". I checked everything and i finally made a simple site to test the control itself:
Sample.aspx:
<%@ Page Language="C#" MasterPageFile="~/MasterPage.master" AutoEventWireup="true" Inherits="_Default" StylesheetTheme="Intranet" Codebehind="Samples.aspx.cs" %>
<%@ Register assembly="Infragistics4.Web.v14.1, Version=14.1.20141.1015, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.Web.UI.EditorControls" tagprefix="ig" %>
<asp:Content ID="Content1" ContentPlaceHolderID="ContentPlaceHolder1" Runat="Server">
    <div style="padding-top: 20px; padding-bottom: 20px;">
        <asp:Button ID="Button1" runat="server" Text="Test Excel Export"
            onclick="TestOnClick" />
    </div>
    <ig:WebNumericEditor ID="MyWebNumericEditor" runat="server" />
</asp:Content>
Code Behind:
    protected void Page_Load(object sender, EventArgs e)
        Title = "Test";
        this.MyWebNumericEditor.ValueDecimal = 2.3m;
        //this.MyWebNumericEditor.DataMode = NumericDataMode.Decimal;
Generated inner HTML (from IE Dev. Toolbar):
    <INPUT id=ctl00_ContentPlaceHolder1_MyWebNumericEditor_clientState value=|0|013.30|| type=hidden name=ctl00_ContentPlaceHolder1_MyWebNumericEditor_clientState>
    <INPUT style="TEXT-ALIGN: right; IME-MODE: disabled" id=ctl00_ContentPlaceHolder1_MyWebNumericEditor class="igte_Office2007SilverEdit" title=3.00 value=3.00 alt=3.00 type=text name=ctl00_ContentPlaceHolder1_MyWebNumericEditor _editID="-1">
The control shows the value "3.00", but i want it to display "3.20".
Any idea whats wrong? I tried to set different DataModes and different values (ValueDecimal, ValueDouble, ValueText ...). I am testing with IE8, but IE11 does show the same problem.
We recently switched from Infragistics 13.1 to 14.1, maybe something to do with that?
Any help would be much appreciated!
