Hello togheter,
could somebody please support me by the following data binding issue:
On my web site I have two buttons (A & B).
When I click button A, I would like to bind data source A with the dedicated columns to the WebHierarchicalDataGrid.
When I click button B, I would like to bind data source B with the dedicated columns to the WebHierarchicalDataGrid.
HTML:
<body>
<form id="form1" runat="server">
<div>
<asp:ScriptManager ID="ScriptManager1" runat="server"></asp:ScriptManager>
<ig:WebHierarchicalDataGrid ID="WebHierarchicalDataGrid1" runat="server" Height="500px" Width="400px">
<GroupingSettings EnableColumnGrouping="True" GroupAreaVisibility="Visible" GroupByAreaLocation="Top"/>
<Behaviors>
<ig:Activation Enabled="true"></ig:Activation>
<ig:Selection Enabled="true" RowSelectType="Single" CellClickAction="Row" ></ig:Selection>
<ig:RowSelectors Enabled="true" RowNumbering="true" EnableInheritance="true"></ig:RowSelectors>
<ig:Paging Enabled="true" EnableInheritance="true" PagerMode="Numeric" PageSize="100"></ig:Paging>
<ig:Sorting Enabled="true" EnableInheritance="true" SortingMode="Single"></ig:Sorting>
</Behaviors>
</ig:WebHierarchicalDataGrid>
<asp:Button ID="Button_A" runat="server" Text="Button_A" OnClick="Button_A_Click" />
<asp:Button ID="Button_B" runat="server" Text="Button_B" OnClick="Button_B_Click" />
</div>
</form>
</body>
Page_Load:
if(!Page.IsPostBack)
Session["DataSource_Session"] = null;
WebHierarchicalDataGrid1.AutoGenerateColumns = false;
object data = Session["DataSource_Session"];
if(data != null)
if (data.GetType() == typeof(A[]))
WebHierarchicalDataGrid1.DataKeyFields = WebHierarchicalDataGrid1.Columns[0].Key;
WebHierarchicalDataGrid1.DataSource = (A[])data;
WebHierarchicalDataGrid1.DataBind();
else if (data.GetType() == typeof(B[]))
WebHierarchicalDataGrid1.DataSource = (B[])data;
Button_Click_Event:
protected void Button_B_Click(object sender, EventArgs e)
try
WebHierarchicalDataGrid1.Columns.Clear();
WebHierarchicalDataGrid1.GridView.ClearDataSource();
BoundDataField dtf = new BoundDataField();
dtf.Header.Text = "Unique ID";
dtf.Key = "uniqueID";
dtf.DataFieldName = "uniqueID";
BoundDataField dtf1 = new BoundDataField();
dtf1.Header.Text = "Value B";
dtf1.Key = "valueB";
dtf1.DataFieldName = "valueB";
WebHierarchicalDataGrid1.Columns.Add(dtf);
WebHierarchicalDataGrid1.Columns.Add(dtf1);
B[] valueList = new B[10];
for (int i = 0; i < 10; i++)
B obj = new B();
obj.uniqueID = i;
obj.valueB = "Value B " + i.ToString();
valueList[i] = obj;
WebHierarchicalDataGrid1.DataKeyFields = WebHierarchicalDataGrid1.Columns[0].Key WebHierarchicalDataGrid1.DataSource = valueList;
WebHierarchicalDataGrid1.GridView.DataKeyFields = WebHierarchicalDataGrid1.DataKeyFields;
WebHierarchicalDataGrid1.GridView.DataSource = WebHierarchicalDataGrid1.DataSource;
WebHierarchicalDataGrid1.GridView.DataBind();
WebHierarchicalDataGrid1.RefreshBehaviors();
Session["DataSource_Session"] = valueList;
catch (Exception ex)
string msg = ex.Message;
protected void Button_A_Click(object sender, EventArgs e)
dtf1.Header.Text = "Value A";
dtf1.Key = "valueA";
dtf1.DataFieldName = "valueA";
A[] valueList = new A[10];
A obj = new A();
obj.valueA = "Value A " + i.ToString();
Data_Source_Class:
public class A
Int64 _uniqueID;
public Int64 uniqueID
get { return _uniqueID; }
set { _uniqueID = value; }
string _valueA;
public string valueA
get { return _valueA; }
set { _valueA = value; }
public class B
string _valueB;
public string valueB
get { return _valueB; }
set { _valueB = value; }
Thanks in advanced.
Hi..im new to infragistics controls ,im using webhierarchicaldatagrid in my project
how to bind data to infragistics webhierarchicaldatagrid through javascript, im having data in datatable ,
dtParent to bind data and dtchild to bind records to bands ..i.e onexpanding a row dtchild has to bind
Hello help123,
I am glad that your issue is resolved.
Please let me know if you have any additional questions.
Hi, with the new version the behaviour is correct. Thanks and best regards
I noticed that in your sample project you are using the RTM build of version 14.1 - 14.1.20141.1015.
Could you please try downloading the latest service release available for NetAdvantage 14.1, which currently is 14.1.20141.2283. This could be achieved by following these steps:
1) Go to our web site www.infragistics.com and log with your account.
2) Click Support/Account in the top right corner of the page
3) You will see Welcome, [Your name] on the top of the menu that will appear. Click on the Welcome word.
4) This will lead you to My Keys&Downloads section. Select your product from the list
Under the Service Releases tab you will find the latest service release available for download.
Please test your sample with this service release and let me know whether you are still experiencing this issue.
Hi, please see attachment.
