I have code to count the number of rows with an unbound checkbox checked. I'm using to the get_checkedCount() method to return the value.
Now I'm trying to count the number of rows with a bound checkbox, and the get_checkedCount() always returns zero.
Is there a different method I should be using to count the number of bound checkboxes checked?
Hello Crendall,
Thank you for your patience.
This behavior is by design, get_checkedCount() method could be used only with UnboundCheckBoxField column. If you want to get only the count of them I can suggest you to check the data source and particularly the field related to the checkbox. For example you can perform Sql command that will return you all values of "DISCONTINUED" which are true, in other words which will be shown in the grid as Checked checkboxes.
Thank you for reporting this.
By my opinion this should work.
I have asked our engineering staff to examine this further. To ensure that it will receive attention, I have logged this behavior in our internal tracking system with a Development ID of 181529. A support case is created on your behalf with number CAS-144243-B2W6M0 , so that you can be notified when the bug is fixed. You can find your active cases under Account - Support Activity in our website. Select your ticket and go to Development Issues tab to view the status of related bugs.
Let me know if I may be of further assistance.
