335
Grid shows old data after batch update - unless I reload it once again
Hello, I have a little problem in a pretty straight forward scenario:
A WebHierarchicalDataGrid is filled with data from a DataSet on every PageLoad event with the following settings
- DataViewState is disable
- ViewState enabled (inherit)
- AutoCrud disabled
- BatchUpdate enabled
- DataSourceId is not set
Like I said, in the end of PageLoad, my BindGrid method is called
Protected Sub BindGrid()
   Dim ds As DataSet = New DataSet
      ds.Tables.Add(GetData(ddlEmployee.SelectedValue))
      WebHierarchicalDataGrid1.DataSource = ds
      WebHierarchicalDataGrid1.DataBind()
End Sub
Now, when update data in the grid, I manually update the database inside the RowUpdating event by calling a stored procedure.
The problem is - after all the rows have been updated and the page reloads, I still get the old values. Only if I refresh the page again, then I see the new values. So it seems to me, that when pressing the save button, the PageLoad is called, loading the still not updated, old values from the database to the grid, then the rows are updated in the database, but the grid shows the data that was load before the update.
What can I do. I cannot find a event that is called after all the rows have been updated so that I could rebind the grid to the updated datasource. Also, setting the DataViewState does not work, because it tells me that the datasource has no primary key. I would prefer a way without DataViewState though.
Thanks a lot, Kevin
